When overclocking, you will often find yourself in a position where you will need to reset your CMOS as a result of pushing your system too far. As a lot of times, it can be less than simple to get to the battery and jumper, you may fidn this useful.
On a unsuccessful try at POSTing, restart your computer. As soon as power is following, start tapping the Ctrl key. It will revert your BIOS to stock settings without any need of even taking the side of your case off. You can then enter your BIOS (by pressing Delete or whichever key your particular BIOS uses) and change your settings again.
What makes this exceptionally great, is that it doesn't reset the settings you have changed in your BIOS. Just makes your computer boot on default settings. So you can continue to tweak without spending the time changing everything back.
K wou juist posten, toen zag k dat t al gepost was van handleiding, lol.
