Aqua-Computer Ultitube D5 - elegant and quiet
HighFlow
Aqua-Computer heeft hun nieuwe serie D5 reservoirs (combo's) gelanceerd!
The new containers of the ULTITUBE D5 series are made from highly resistant borosilicate glass in Germany and offer the possibility of installing a pump from the very popular D5 series.
For the first time it was possible to manufacture a glass expansion tank without additional, usually disturbing struts or pipes. The other components of the container are manufactured by Aqua Computer using CNC production from Delrin.
Aqua Computer goes one step further and integrates a washable stainless steel filter into the tank bottom, which at the same time enables optimal ventilation of the system.
A lot has been done for usability. The seals are designed as molded parts that snap into the container and thus always remain in the right place. In addition, the 55 mm diameter container has an extremely large filling opening. The pump can be assembled by hand by simply screwing it on without tools.
In the PRO version there is an optically invisible pressure compensation system integrated in the lid. In this version, the container also comes directly with an LED ring, which has digital LEDs and can be connected to the RGBpx system known from Aqua Computer. With an optionally available adapter, a connection to most mainboards is also possible.
The ULTITUBE D5 reservoirs are also offered by Aqua Computer ex works with a D5 NEXT pump or a D5 PWM pump.
The containers have a diameter of 65 mm and are available in lengths of 100, 150 and 200 mm.
Nu alvast te bestellen via HighFlow:
Aqua-Computer Ultitube Series
Jason Aqua-Computer VISION RGBpx connection terminal for kryographics HighFlow Product Suggesties en Nieuws 0
Jason Aqua-Computer cuplex kryos NEXT RGBpx HighFlow Product Suggesties en Nieuws 0
Freddy Aqua-Computer Farbwerk 360 HighFlow Product Suggesties en Nieuws 1
U Aqua computer airplex radiatoren *Modularity system 360mm *Radical 240mm HighFlow Product Suggesties en Nieuws 3
Hightower Aqua computer res Waterkoeling 1
Freddy Aqua-Computer Farbwerk RGB controllers en ledstrips HighFlow Product Suggesties en Nieuws 11
R Aqua-Computer Ramplex Copper Edition RAM Block op Dominator platinum? Waterkoeling 3
H Aqua-Computer Tubemeter Waterkoeling 0
l3p [VERKOCHT] Aqua-Computer AMS Airplex Modularity System + veel extra's Verkocht 3
R Aqua-Computer Double Protect Ultra - Orange 1000ml HighFlow Webshop 4
arwin74 nieuwe aqua computer goodies HighFlow Product Suggesties en Nieuws 7
alain-s [IN-ACTIVE] Aqua-Computer RadGrillz Stripes 3x120mm Silver Verkocht 1
arwin74 [VERKOCHT] Aqua-Computer (electronic) Flow Meter G1/4 (High Flow) Verkocht 13
alain-s Aqua-Computer RGB illumination module for aquaero 5 HighFlow Product Suggesties en Nieuws 2
Harjo [CANCELLED] Aqua-Computer RadGrillz Stripes 3x120mm Silver Verkocht 11
Marcel2102 Aqua-Computer Aquastream / EHEIM Pomp 2x stuk Waterkoeling 7
R [INACTIVE] Aqua computer cuplex HD s775 mounting kit Gevonden 5
ForresT aqua computer rads HighFlow Product Suggesties en Nieuws 6
T Aqua Computer XT ultra krijg ik niet werkend!! Waterkoeling 7
Alex Aqua Computer Cuplex Kryos HighFlow Product Suggesties en Nieuws 5
fasster Aqua-Computer Aquacover DDC Pomp Top Waterkoeling 3
M flowmeter op de ultra XT van aqua computer Waterkoeling 6
k.3nny aqua computer cuplex HD am2+ mount HighFlow Product Suggesties en Nieuws 4
aadje93 Aqua-Computer Ramplex Copper Edition RAM Block - G1/4 vraagje.. Waterkoeling 15
vincent Aqua-Computer Airplex Revolution 420/360 G1/4 HighFlow Product Suggesties en Nieuws 3
