Singularity Computers Wraith Mini-ITX Chassis / Case
Singularity Computers heeft weer iets nieuws, de Wraith Mini-ITX behuizing!
Net als de Spectre een geïntegreerde distributie paneel (reservoir) als moederbord tray, maar dan een tikkie kleiner voor ITX systeempjes :)
Nu direct uit voorraad leverbaar bij HighFlow:
Introducing Wraith:
From the people who brought you the first ever PC Chassis liquid cooling integration, we now bring you Wraith. In development for the past 2 years since the release of Spectre, Wraith has all of the features of Spectre but in a smaller ITX form factor. Now you can fit the most extreme components on the market into a very small space and have the ultimate in liquid cooling. Integrated cooling components include the Reservoir, D5 Pump Top, D5 Pump Cover, Fill Port, Drain Port and over half of the cooling loop. Integration and compatibility do not have to work against each other when you have more than a decade of experience building extreme liquid cooled systems. From a combination of statistics and experience we have created a port layout which will not inhibit compatibility or your creativity. Wraith has a cable cover so that stock cables can be used in a clean configuration, custom cables are not necessary. Despite its compact size Wraith can fit full sized GPUs, 2x 240mm radiators, 13x 2.5” drives and even a 3.5” drive and more. The case is designed to be modified and every component can be completely disassembled. As always we look forward to seeing your creativity with our design.
Jason Singularity Computers Wraith 2.0 ITX/DTX Case HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith ITX/DTX Case HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX - Black HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX – Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX - Black or Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini-ITX Case/ Behuizing HighFlow Product Suggesties en Nieuws 0
Slader Singularity Computers Multi-Node ARGB+Fan? Waterkoeling 3
Jason Singularity Computers PowerBoards HighFlow Product Suggesties en Nieuws 1
anub1s18 Singularity Computers Protium Reservoir Tube Replacement 100mm? HighFlow Product Suggesties en Nieuws 7
Jason Bijna uitverkocht: Singularity Computers Protium - SALE% HighFlow Product Suggesties en Nieuws 0
Jason SALE% - Singularity Computers Protium Series HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 Zwart & Zilver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Resonance Single & Dual HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 Elite HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black & Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black/Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Protium 150 D5 – Reservoir Combo HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 2.0 Case, 10% korting aanbieding HighFlow Product Suggesties en Nieuws 0
Freddy 25% korting op Singularity Computers, zolang de voorraad strekt! HighFlow Computer Cooling Shop 0
Freddy 20% korting t/m zondag 8 maart op Singularity Computers! HighFlow Computer Cooling Shop 3
Freddy Singularity Computers Resonance, Reservoir Pump Combo / Distribution Plate HighFlow Product Suggesties en Nieuws 7
Freddy Singularity Computers Spectrum RGB/UV Rigid 30cm LED Strip HighFlow Product Suggesties en Nieuws 1
Freddy Singularity Computers Spectre 2.0 case / behuizing HighFlow Product Suggesties en Nieuws 8
Freddy Dit weekend 15% korting op Singularity Computers! HighFlow Computer Cooling Shop 0
Freddy Singularity Computers Giveaway, Juli 2018 HighFlow Computer Cooling Shop 11
Freddy Singularity Computers 20% kortingsactie dit weekend! HighFlow Computer Cooling Shop 0
Freddy Singularity Computers Protium Reservoirs HighFlow Product Suggesties en Nieuws 2
anub1s18 Singularity Shift Motherboard 24 Pin 180 Degree HighFlow Product Suggesties en Nieuws 2
Tath Singularity Beast IV Gallery & Build Logs 8
Tath TATH Singularity Beast III Rebuild Gallery & Build Logs 35
D Aqua Computers D5 Next Software Problemen & Oplossingen 6
D [ADVIES] 4X r9 290X verdeeld over 2 computers Waterkoeling 35
M het ouders met computers topic. Algemene Discussies 29
B Steam & 2 Computers Hardware & Software 9
P nieuw! Jeroen, en de PC (geef geen namen aan computers) Introductie: Stel jezelf en jouw PC voor 10
