NL-NSB Twin Asus Rampage III Gene
w4rlock
biertje ?
- Naam product
NL-NSB Twin Asus Rampage III Gene zwart Acetal/delrin
- Naam fabrikant
Liquid Extasy
- Omschrijving product
full cover waterblock Asus Rampage 3 gene
- Link/URL naar website van de fabrikant + pagina van het product
http://liquid-extasy.de/index.php/mb-kuehler/mb-chipsatz/asus/nl-nsb-twin-asus-rampage-iii-gene-detail
- Adviesprijs en eventueel een link naar het productpagina bij andere shops.
79,90 €
CPU waterblock associated with liquid extasy rampage 3 gene cooler
Hi, i bought the liquid extasy rampage 3 gene waterblock 6 months ago, it look's fine but it's steel in his box because all my CPU cooler are incompatibles.
I've tried 2 differents swiftech cpu waterblocks and one hole is too closed to the NB waterblock.
The screw hit the Nb waterblock.
So i'm looking for a compatible and efficient cpu waterblock
Best regards
Hello,
I'm using the xspc rasa block but i dont know it will fit next to the nb block.
But the easiest way is to grind the cpu block bracket i think.
Atleast thats what i'm gonna do when it doesnt fit.
But if you want to get rid of it let me know ;)
Asphiax Watercool HEATKILLER NSB Rev3.0 Ni Northbridge / Southbridge (Nickel Plated) edition HighFlow Product Suggesties en Nieuws 3
Jason Barrow 14mm OD - Twin Seal Hard Tube 90 Degree Compression Fitting HighFlow Product Suggesties en Nieuws 0
C Corsair Air Series AF120 LED Quiet Edition Wit Twin Pack, 120mm HighFlow Product Suggesties en Nieuws 2
Freddy Daytona USA Twin Cab (Arcade) Overige Builds 46
Rooneys [VERKOCHT] 3x Corsair SP120 Twin Pack, 120mm Verkocht 1
A waterblock voor deze grafische kaart MSI N660-TF-2GD5/OC Twin Frozr III GeForce GTX HighFlow Product Suggesties en Nieuws 2
Cygnitr0n [Casemod] Raspberry Pi "Silent 4 Twin Cooler" Gallery & Build Logs 8
arwin74 [VERKOCHT] 2* MSI N470GTX Twin Frozr II Verkocht 8
Legendary1985 Waterblock voor MSI GTX680 4GB Twin Frozr Waterkoeling 2
LRAB Custom MSI 560Ti Twin-frozr II Fullcover block Cases en Modding 84
F Arctic Cooling Accelero Twin Turbo 6990 HighFlow Product Suggesties en Nieuws 3
K [CLOSED] MSI N560GTX-Ti Twin Frozr II/OC Gesloten 2
R block voor MSI R6950 Twin Frozr III Advies Waterkoeling Setup 5
F Arctic cooling Twin Turbo II Handleidingen en Installatie Tips 1
H [REFUSED] Accelero Twin Turbo Verkocht 0
Wouzke MSI GTX 560 TWIN FROZR ii OC full cover block Waterkoeling 2
R Arctic Cooling Accelero Twin Turbo 6990 HighFlow Product Suggesties en Nieuws 2
R MSI 5850 Twin Frozr II Advies Waterkoeling Setup 13
W EK GTX 580 backplate op een Twin Frozr kaart Cases en Modding 9
S Revoltec Ultra Bright Cold WHITE Light - 30cm TWIN set Cases en Modding 10
brazen Revoltec Ultra Bright Cold WHITE Light - 10cm TWIN set Cases en Modding 1
Thierry Mod-smart twin leds HighFlow Product Suggesties en Nieuws 9
Sanders Revoltec Ultra Bright Cold UV Light - 10cm TWIN set HighFlow Product Reviews 8
Robin Arctic Cooling Accelero Twin Turbo HighFlow Computer Cooling Shop 3
S koelblokjes ac twin turbo laten los. Cases en Modding 13
M Arctic Cooling Accelero Twin Turbo en ati 4980 in Crossfire Hardware & Software 12
L Twin Turbo Overige Koeling 12
L Bestelling AC Accelero Twin Turbo HighFlow Testimonials / Shopreviews 0
Bl4ckj4ck666 Asus rog strix x570-e gaming monoblock Handleidingen en Installatie Tips 6
Hightower Asus aio 360 HighFlow Product Suggesties en Nieuws 10
V asus aio cooler HighFlow Product Suggesties en Nieuws 3
M Asus M.2 standoff en screw HighFlow Product Suggesties en Nieuws 3
T Asus Zenith treadripper 1950X waterkoeling Gallery & Build Logs 7
