JaPeMo
JP[0] by JaPeMo
Sponsors
My first mod started for 3 years ago, I've picked up this habit.
I am currently working in Paris (late November), but I'm already working on my new project, JP[0]
Still under study and sketching. All drawings and doodles on paper, even napkins taking cafes, which is where the best ideas are translated ...
Hardware
Motherboard: Asus Rampage IV Black Edition
Micro: Intel i7-3930K
RAM: 16GB Team Xtreem DDR3 PC3-20800 2600MHz (10-12-12-31) Quad Channel kit 4x4GB
GPU (VGA): EVGA GTX 670 FTW 2Gb SLI
Case: Case Labs Mercury S8
Hot Swap: Icy Dock MB973SP-2B
Power Supply: Seasonic X1250W (SS-1250XM)
Sound Card: Asus Xonar Essence STX
Active monitors: KRK Rokit 5 G2 (x2)
Liquid and Air cooling
Pumps: Swiftech MPC-355 (x2)
Top: Aquacomputer aquacover dual DDC
Reservoir: EK Multioption RES X2-250 Advanced
Block PB & CPU: EK-FB ASUS R4BE Monoblock - Acetal+Nickel
Block GPU: EK-FC680 GTX+ - Acetal (x2)
+ EK-FC Bridge SINGLE CSQ
Tube: Acrylico 16/12 Clear
Liquido: Mayhems X1 - Oil Black 1ltr liquid cooling
Fittings, adapters and accesories:
EK Water Blocks
EEK-HDC Fitting 16mm G1/4 - Black (x22)
EK-PSC Adapter 90? G1/4 Black (x12)
Koolance
Fitting Coupling Adapter, *Black* Male-Female, 20mm (x4)
Fitting Coupling Adapter, *Black* Male-Male (x4)
Fitting Coupling Adapter, Swiveling Male-Male (x1)
Check Valve (x1)
Bitspower
Bitspower Flow Sensor Matt Black (x1)
G1/4 Matt Black CaseTop Water-Fill SET (x7)
G1/4 Matt Black IG1/4 Extender (x4)
G1/4 Matt Black Mini Dual G1/4 Extender (x10)
Bitspower G1/4 Matt Black IG1/4 Extender 15mm (x1)
Bitspower G1/4 Matt Black IG1/4 Extender 25mm BP-MBWP-C62 (x1)
Matt Black Mini Valve With Black Handle (x3)
Others
Filter(x1)
Te (x1)
Controller:
Aquaero 5 Pro w/ water block + Flow sensor "high flow" G1/4 for aquaero + RGB Module
PowerAdjust2 USB Ultra (x2)
Temperature sensors:
Ambient (x1)
Inside case (x2)
Radiator air out (x1)
In-line in/out radiators (x4)
Radiators: Alphacool NexXxoS UT60 Full Copper 360mm (x2)
Fans:
Noiseblocker NB-BlackSilent Pro 120mm PL-2 1400r.p.m. (x8)
Noiseblocker NB-BlackSilent Pro 80mm P-1 1500r.p.m. (x5)
Others: Recycled
Lighting
5050 RGB LED Strips and UV
Documents & Galery
Acces to documents and galery about worklog
Link to Google Drive
Sponsors
Hardware
EK Water Blocks
Koolance
Check Valve (x1)
Bitspower
Others
Filter(x1)
Te (x1)
Controller:
Ambient (x1)
Inside case (x2)
Fans:
Others: Recycled
Lighting
Documents & Galery
