Beste overclockers,
Ben momenteel bezig met een overclock a.d.h.v. een oc guide.
Hij draait nu 4ghz en al 11 minuten stabiel op 65 graden (lucht).
Maar ik wil even mijn settings laten checken door de echte pro´s.
CPUz:
Ai Overclock Tuner - Manual
CPU Ratio Setting - Auto
Intel (R) SpeedStep (TM) Tech - Enabled
Intel (R) Turbo Mode Tech - Enabled
BCLK Frequency - 190
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1523MHz - If you use memory that is slower than 1600MHz, you can use the next lowest setting here, however, if you use faster memory, such as 1866MHz or even 2000MHz, please stick with this setting for now.
DRAM CAS# Latency - 8 DRAM Clock
DRAM RAS# to CAS# Delay - 8 DRAM Clock
DRAM RAS# PRE Time - 8 DRAM Clock
DRAM RAS# ACT Time - 24 DRAM Clock
CPU Voltage 1.25000v - This is our maximum Vcore
CPU PLL Voltage - Auto
QPI/DRAM Core Voltage - 1.3v - We need to up this to 1.3v to maintain stability, or at least I did on my CPU, your mileage may vary and you may need slightly more or slightly less.
IOH Voltage - Auto
IOH PCIE Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
DRAM Bus Voltage - 1.66v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
Load-Line Calibration - Enabled
CPU Differential Amplitude - Auto
CPU Clock Skew - Auto
CPU Spread Spectrum - Auto
IOH Clock Skew - Auto
PCIE Spread Spectrum - Auto
Hoor het wel
Johnny
CPUz:
PCIE Fequency - 100
IOH Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
Hoor het wel
Johnny
