Blackruby
Senior Member
Mijn chatgesprek met Intel:
info: Please wait for a site operator to respond.
info: You are now chatting with 'Otto'
Otto: Hello. Thank you for visiting Intel Customer Support. How can I help?
you: Hello, I got some problems with my computer. I'm getting errors and BSOD's when I'm running my memory on 1866MHz.
Otto: This processor only works at 1066MHz
Otto: Therefore, any settings higher than this, can create problems.
you: Why does Corsair sells memory at 1866Mhz then?
Otto: Future processors will support memory speeds up to 1600MHz
you: Do you mean the new D0 stepping?
Otto: No, the new models that have not yet been released
you: The 950 and 975?
Otto: They have not been released yet
you: So, they will support 1600Mhz?
Otto: yes
you: Will there be a cheaper one that will support 1600MHz?
Otto: I do not understand your question. The current processors will not support this spead
Otto: speed
you: Will there be a 930 or something? A 920 with support for 1600Mhz?
Otto: No
you: Allright, isn't there anything I could do to get my current CPU to do 1866MHz on the RAM?
Otto: No
you: Allright, thanks for the support.
Otto: You are welcome
Otto: Thank you for using chat. I look forward to chatting with you again. We value your suggestions and would appreciate it if you would take a moment to complete our survey. The survey will appear when you click "Close'' to close the chat window. Have a nice day.
