Aquacomputer Kryographics GTX 980 Acrylic Glass edition, Nickel plated version
mystiqu
- Naam product
- Naam fabrikant
Aquacomputer
- Omschrijving product
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX 980 with 4 GB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 980 water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
To allow an even contact pressure in the area of the voltage regulators the block comes with a small stainless steel backplate.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
- Link/URL naar website van de fabrikant + pagina van het product
Aqua Computer Webshop - kryographics für GTX 980 acrylic glass edition, vernickelte Ausführung 23614
- Link/URL naar Reviews van het product
XtremeHardware
- Adviesprijs en eventueel een link naar het productpagina bij andere shops.
109,90 @ AquaComputer
- Foto's van het product
Afbeeldingen uit bovenstaande review geplukt.
- Overige informatie
Is ook compatible met een paar GTX 970 kaarten die een ref 980 PCB hebben.
Klikje voor welke kaarten ala CoolingConfigurator / EKWB
Levertijd / prijs ? Wil er vóór TP een bestellen :)
X aquacomputer leakshield standalone Advies Waterkoeling Setup 3
Wasmachineman_NL Aquacomputer kryoM.2 Micro HighFlow Product Suggesties en Nieuws 1
M Aquacomputer Octo voedings kabel Problemen & Oplossingen 2
arwin74 ervaringen met aquacomputer airplex system? Advies Waterkoeling Setup 0
the_cyberspace Onderdeel Aquacomputer aqualis base 450ml HighFlow Product Suggesties en Nieuws 5
the_cyberspace Aquacomputer Aqualis Base HighFlow Product Suggesties en Nieuws 4
XenoMorpH Aquacomputer Farbwerk RGB led-controller Electronica 2
Tath AquaComputer Power Adjuster 3 HighFlow Product Suggesties en Nieuws 1
Y Aquacomputer aquagrafix 6990 HighFlow Product Suggesties en Nieuws 2
Thieutje Aquacomputer Aquaero 5 XT uitbreidings onderdelen :) HighFlow Product Suggesties en Nieuws 5
B Nieuwe Aquacomputer producten :) HighFlow Product Suggesties en Nieuws 8
coolfris Aquacomputer: "Aqualis" reservoir gemaakt van echt glas HighFlow Product Suggesties en Nieuws 20
Legendary1985 [VERKOCHT] BP matt black aftapkraan + Aquacomputer inline Temp sensor Verkocht 12
V [TKA] diverse waterkoelings onderdelen aquacomputer koolance ek. Verkocht 7
Sw333t [CANCELLED] Aquacomputer Aquatube G1/8 Black Verkocht 4
Sw333t Vraag omtrent adapters / omzetstukken voor een Aquacomputer Aquatube Waterkoeling 7
Mannozels [VERKOCHT] Sapphire HD6850 toxic met Aquacomputer waterblock Verkocht 4
coolfris Nieuwe AquaComputer radiators: airplex modularity system HighFlow Product Suggesties en Nieuws 18
Harjo [VERKOCHT] Aquacomputer Aquatube G1/4 Verkocht 5
k.3nny [IN-ACTIVE] [2x CPUblokjes + 3x1GB]Heathkiller,aquacomputer,OCZ Verkocht 11
Harjo [GEANNULEERD] Nvidia 7600 + aquacomputer wc blok Verkocht 7
U Aquacomputer aquaero 5 PRO / XT / LT HighFlow Product Suggesties en Nieuws 34
W EVGA GeForce GTX 460 icm een aquacomputer full-cover blok Waterkoeling 2
V Nieuw van aquacomputer de:powerbooster HighFlow Product Suggesties en Nieuws 6
Thierry Aquacomputer tempsensor HighFlow Product Suggesties en Nieuws 5
Reqlex Aquacomputer pomp/aquaero4.00/Multiswitch1.41 Waterkoeling 1
V aquacomputer mem block. HighFlow Product Suggesties en Nieuws 12
V aquacomputer chipset block HighFlow Product Suggesties en Nieuws 5
dopestuff aquacomputer aquajet HighFlow Product Suggesties en Nieuws 4
V De nieuwe Aquacomputer cuplex hd Waterkoeling 22
Jason Aqua-Computer VISION RGBpx connection terminal for kryographics HighFlow Product Suggesties en Nieuws 0
coolfris kryographics for GTX 780 acrylic glass edition, nickel plated version HighFlow Product Suggesties en Nieuws 4
Wasmachineman_NL Hardware Labs GTX radiators in ongewone maten (80/160 en 92/184mm) HighFlow Product Suggesties en Nieuws 1
R [Waterkoeling], €300 euro, i5-8600K, nVidia GTX-1080ti Waterforce Advies Waterkoeling Setup 4
R EK-FC GeForce GTX FE 980 ti Waterkoeling 1
0 [Waterkoeling] Luchtdichte-anti-kattenharen-case, 1000 euro, i7 8700K, GTX 1080Ti Advies Waterkoeling Setup 9
