Aquacomputer aquaero 5 PRO / XT / LT
U
UgotHeinzzd
Guest
=== update 01-03-11 ===
In de HighFlow shop voor pre-order:
Aqua-Computer Aquaero 5 PRO USB fan controller, graphic LCD
Aqua-Computer Frontplate for aquaero 5 PRO aluminum black
Aqua-Computer Aquaero 5 XT USB fan controller, graphic LCD, touch control, IR remote control
Aqua-Computer Frontplate for aquaero 5 XT aluminum black
Zag net een nieuw speeltje! Geen idee of er al een post van is en of deze in de shop komt?
aquaero 5 PRO USB fan controller, graphic LCD Product No.: 53090 adviesprijs in Duitsland €119,90
Frontplate for aquaero 5 PRO aluminum black Product No.: 53091 adviesprijs in Duitsland € 9,90
Please note: The aquaero 5 is scheduled to be shipped out beginning in the end of february 2011!
The aquaero is an absolutely autonomous working microprocessor-controlled device with USB 2.0 interface. All speed parameters and sensor values can be set and visualized in an user-friendly menu or through an even easier to use PC-software. Additionally, the graphic LC display can be used to display almost any information using the popular LCD software LCDHype.
The key features of the aquaero 5 include:
· Programmable four channel fan controller
· Graphic LC display with backlight (except LT)
· USB 2.0 and aquabus interface
· Four fan outputs with current measurement
· Versatile control options
· Eight temperature sensor inputs
· Flow sensor input
· Universal IR receiver (except LT)
· Output for IR transmitter
· Three LED outputs
· Potential-free switch
· Two additional power outputs
· Extensive alarm options
· Acoustical alarm
· Speed signal output for status evaluation
· Expandable to a maximum of 10 fan channels
Several aqua computer products can be used to expand the functionality of the aquaero 5 Controller. These expansions are dynamically mapped into the menus and display pages of the aquaero, creating a consitent control system rather than individual devices.
In maximum configuration, the following devices can be connected to an aquaero 5 simultaneously:
Two aquastream XT pumps
Six poweradjust 2 controllers
One tubemeter
Two multiswitches
aquaero 5 XT USB fan controller, graphic LCD, touch control, IR remote control Product No.: 53089 adviesprijs in Duitsland €159,90
Frontplate for aquaero 5 XT aluminum black Product No.: 53092 adviesprijs in Duitsland € 9,90
· Flow sensor input
· Three LED outputs
· Acoustical alarm
One tubemeter
Two multiswitches
aquaero 5 LT USB fan controller Product No.: 53095 adviesprijs in Duitsland €159,90
The aquaero is an absolutely autonomous working microprocessor-controlled device with USB 2.0 interface. All speed parameters and sensor values can be set and visualized in an user-friendly PC-software.
· Flow sensor input
· Three LED outputs
· Acoustical alarm
Several aqua computer products can be used to expand the functionality of the aquaero 5 Controller. These expansions are dynamically mapped into the device, creating a consitent control system rather than individual devices.
One tubemeter
Two multiswitches
aquaremote Infrarotfernbedienung für aquaero 5 Product No.: 53089 adviesprijs in Duitsland €14,95
Keyboard, mouse and media controls: Use your aquaero 5 as a universal input device.
The aquaremote (included in delivery with the aquaero 5 XT) turns your aquaero 5 into a universal input device with a complete keyboard, mouse functions and media keys.
By pressing one button on the remote control, you can switch between function levels:
In aquaero mode, the aquaremote allows to comfortably configure your aquaero 5. Especially keying texts in is significantly more effective than using the buttons of the aquaero 5 itself.
In PC mode, your commands are sent directly to the PC using the USB keyboard interface of the aquaero 5, which means that the remote control is functional for BIOS configuration as well. Additionally, the function of the right hand directional pad including media keys can be switched from normal keyboard commands to media commands.
The keyboard of the aquaremote is equipped with many special characters including $, £ and € symbols. The different key levels (shift. strg etc.) are displayed as pop-ups on the display of the aquaero 5. The PC mouse pointer can be moved using the left hand directional pad equipped with eight push switches, allowing diagonal mouse movement.
Scope of delivery:
aquaremote infrared remote control
two batteries type micro / AAA
Compatible with:
aquaero 5 XT (art. 53089)
aquaero 5 PRO (art. 53090)
Not compatible with aquaero 5 LT or aquaero 4.00 - these devices do not feature an infrared receiver!
Die komt zekers in de shop!
Levertijd is nog niet helemaal duidelijk, daarom nog niet toegevoegd.
Als iemand voorkeur heeft voor pre-order, graag even laten weten, dan voegen we alvast toe :)
Het is inderdaad overkill als je het mij vraagt, er is ook gewoon een passief koellichaam voor te krijgen. Deze wordt alleen bij de XT standaard meegeleverd geloof ik. Of je dit nodig hebt is denk afhankelijk van het vermogen wat je van de aquaero gebruikt.
Heat sink for aquaero 5 Product No.: 53094 adviesprijs in Duitsland € 8,90
voor mij deze twee voor de pre-order:
Gaat op de bestellijst :)
We kunnen het verwachten over 2-3 weken ongeveer volgens Aqua-Computer.
Nu de levertijd bekend is, zullen we deze producten deze week toevoegen aan de shop (zal hier een update daarvoor posten).
Freddy weet jij of deze flow sensor van Aqua-Computer ook geschikt is voor de aquaero 5 XT?
Voor de zekerheid vraag ik het maar even al lijkt het me van wel?
Ow, kun je me eventueel nog dingen adviseren over en voor de aquaero 5 XT? Aangezien ik voor het eerst gebruik zal maken van zo'n controller. Bvd.
Die is geschikt voor de aquaero 5 XT , let op !! Deze flow meter nooit op het moederbord aansluiten dat geeft kortsluiting.
Hoe weet je dit zo zeker, het compatibel zijn met de XT? Aangezien ik het niet heb kunnen vinden op hun site. Die dingen zullen vast wel universeel inzetbaar zijn, wil het alleen zeker weten. Misschien een stomme opmerking hoor, waarom zou ik de flow meter op me moederbord aan willen sluiten als ik een XT heb (moet hem nog binnen krijgen) ;)!?
Geloof me nou maar, deze flowmeter kan op de XT, deze flowmeter is niet universeel inzetbaar alleen icm met producten van aquacomputer. (voorheen koelde ik alles met A.C pompen, aquaero, multi-swits, poweramps, ken het product en software op mijn duimpje)
Mocht je gebruik maken van een dual loop setup kun je zelfs 2 flowmeters erop aansluiten, er is 1 aparte aansluiting voor
de flowmeter, de ander flowmeter kun je op channel 4 van de fan output zetten. je zal dan de channel moeten configeren
als flow funtie via de software.
Voor het aansluiten op het mobo heb ik even vermeld als sommige mensen deze topic lezen en denken "'cool een flowmeter die sluit ik op mijn fan header op mijn mobo"' om de rpm uit te lezen, dit gaat gegarandeerd roken.
Deze flowmeter kan ook op de volgende producten mocht je geen gebruik maken van een aquaero :
Aqua-Computer Aquastream XT USB 12V - Ultra
Aqua-Computer Poweradjust 2 USB - Ultra Version
Hoe weet je dit zo zeker, het compatibel zijn met de XT? Aangezien ik het niet heb kunnen vinden op hun site. Die dingen zullen vast wel univeerseel inzetbaar zijn, wil het alleen zeker weten. Misschien een stomme opmerking hoor, waarom zou ik de flow meter op me moederbord aan willen sluiten als ik een XT heb (moet hem nog binnen krijgen) ;)!?
because he's the aquacomputerman ;) :p hehehe
maarem dikke controller, idd leuk voor een volgende build :D yum yum
Thieutje Aquacomputer Aquaero 5 XT uitbreidings onderdelen :) HighFlow Product Suggesties en Nieuws 5
X aquacomputer leakshield standalone Advies Waterkoeling Setup 3
Wasmachineman_NL Aquacomputer kryoM.2 Micro HighFlow Product Suggesties en Nieuws 1
M Aquacomputer Octo voedings kabel Problemen & Oplossingen 2
arwin74 ervaringen met aquacomputer airplex system? Advies Waterkoeling Setup 0
the_cyberspace Onderdeel Aquacomputer aqualis base 450ml HighFlow Product Suggesties en Nieuws 5
the_cyberspace Aquacomputer Aqualis Base HighFlow Product Suggesties en Nieuws 4
M Aquacomputer Kryographics GTX 980 Acrylic Glass edition, Nickel plated version HighFlow Product Suggesties en Nieuws 5
XenoMorpH Aquacomputer Farbwerk RGB led-controller Electronica 2
Tath AquaComputer Power Adjuster 3 HighFlow Product Suggesties en Nieuws 1
Y Aquacomputer aquagrafix 6990 HighFlow Product Suggesties en Nieuws 2
B Nieuwe Aquacomputer producten :) HighFlow Product Suggesties en Nieuws 8
coolfris Aquacomputer: "Aqualis" reservoir gemaakt van echt glas HighFlow Product Suggesties en Nieuws 20
Legendary1985 [VERKOCHT] BP matt black aftapkraan + Aquacomputer inline Temp sensor Verkocht 12
V [TKA] diverse waterkoelings onderdelen aquacomputer koolance ek. Verkocht 7
Sw333t [CANCELLED] Aquacomputer Aquatube G1/8 Black Verkocht 4
Sw333t Vraag omtrent adapters / omzetstukken voor een Aquacomputer Aquatube Waterkoeling 7
Mannozels [VERKOCHT] Sapphire HD6850 toxic met Aquacomputer waterblock Verkocht 4
coolfris Nieuwe AquaComputer radiators: airplex modularity system HighFlow Product Suggesties en Nieuws 18
Harjo [VERKOCHT] Aquacomputer Aquatube G1/4 Verkocht 5
k.3nny [IN-ACTIVE] [2x CPUblokjes + 3x1GB]Heathkiller,aquacomputer,OCZ Verkocht 11
Harjo [GEANNULEERD] Nvidia 7600 + aquacomputer wc blok Verkocht 7
W EVGA GeForce GTX 460 icm een aquacomputer full-cover blok Waterkoeling 2
V Nieuw van aquacomputer de:powerbooster HighFlow Product Suggesties en Nieuws 6
Thierry Aquacomputer tempsensor HighFlow Product Suggesties en Nieuws 5
Reqlex Aquacomputer pomp/aquaero4.00/Multiswitch1.41 Waterkoeling 1
V aquacomputer mem block. HighFlow Product Suggesties en Nieuws 12
V aquacomputer chipset block HighFlow Product Suggesties en Nieuws 5
dopestuff aquacomputer aquajet HighFlow Product Suggesties en Nieuws 4
V De nieuwe Aquacomputer cuplex hd Waterkoeling 22
Q Aquaero 6XT - Afstandbediening Problemen & Oplossingen 2
M Aquaero 5 LT 12v pwm uitgang Electronica 4
J Aquaero 6 Pro met 2 pompen en 12 fans. Electronica 4
arwin74 zwart passief koel blok voor de aquaero 6 pro/xt HighFlow Product Suggesties en Nieuws 1
arwin74 Passive heat sink for aquaero 6 HighFlow Product Suggesties en Nieuws 4
I Aquaero 5 onbekend apparaat Waterkoeling 9
arwin74 [Gezoekt]Aquaero Gevonden 1
