Vertienvoudig jouw kracht met een robot pak :D
What's "HAL" (Hybrid Assistive Limb®)? - CYBERDYNE
Vertienvoudig jouw kracht met deze "robot pak" :D
* "Robot Suit HAL" is a cyborg-type robot that can expand and improve physical capability.
* When a person attempts to move, nerve signals are sent from the brain to the muscles via motoneuron, moving the musculoskeletal system as a consequence. At this moment, very weak biosignals can be detected on the surface of the skin. "HAL" catches these signals through a sensor attached on the skin of the wearer. Based on the signals obtained, the power unit is controlled to move the joint unitedly with the wearer's muscle movement, enabling to support the wearer's daily activities. This is what we call a 'voluntary control system' that provides movement interpreting the wearer's intention from the biosignals in advance of the actual movement. Not only a 'voluntary control system' "HAL" has, but also a 'robotic autonomous control system' that provides human-like movement based on a robotic system which integrally work together with the 'autonomous control system'. "HAL" is the world's first cyborg-type robot controlled by this unique Hybrid System.
* "HAL" is expected to be applied in various fields such as rehabilitation support and physical training support in medical field, ADL support for disabled people, heavy labour support at factories, and rescue support at disaster sites, as well as in the entertainment field.
ZwerverRoodbaard
Bred veur de kop
Oke dan :S
Eerste waar ik aan denk bij Hal is toch wel deze man :p
Trouwens vertienvoudigen :S Als je zelf al 100 kg kan drukken, dan kan je met dit apparaat 1 ton drukken :O
Jouw plaatje doet het niet zwerver.
Nu ben ik benieuwd wat voor plaatje het was :D
coolfris
Dat gedeelte voor de benen zou ik wel willen hebben voor op de fiets. :)
Maar hier het pak in aktie :p :
[ame="http://www.youtube.com/watch?v=VSP46lWvxJ4"]
[/ame]
Spankyfart
Nr 13.824.918 of Holland
Dit is vast goed voor je enkels :087:
Zie niet echt iets wat de gewichtdistributie op zijn enkels doet verminderen.
Anyways, wie wil er een pak als je het zelf kan doen :)
[ame=http://www.youtube.com/watch?v=N6Mus_KbQD0]YouTube - Mr. Roboto Dance[/ame]
ZwerverRoodbaard
Bred veur de kop
My name is Earl! Geweldige serie :p
Dat filmpje van het pak is ook vaag trouwens :S Laten ze eerst een reporter een jerrycan water dragen om vervolgens iemand anders met zo'n pak hetzelfde te laten doen. Wat moet ik daar dan van leren/zien?
Source
Mr. Grillmeister
Stond ook al ergens in een post, bij nieuwsbericht op Tweakers.
Je kan met dit ding dan wel 10x zoveel drukken, denk alleen niet dat je polsen 1000KG houden, mocht je zelf 100KG drukken :p
hung
RAS EZEL
als die dingen ook een super sajin modus hebt, dan ben ik verkocht.
die model voor de HAL is best wel lelijk.
maar ik had ook gelezen dat de firma Cyberdyne heete. bekend?? terminator
wijthoef
All Round Computer Addict
handig voor op je werk
vooral als je een zwaar beroep heb!:p ff pakken tegels naar 4 hoog lopen ofzo
Nils
Highflow Clan Member
^^ grappig zoon pak:p zou wel handig zijn voor een bodybuilder:p nieuw wereld record;) maar dan als je pak uitvalt:p whahah dan ben je de klos
Freddy HighFlow Polo Shirts met jouw Nickname, TP13 edition :) Lan Party 341
Freddy Zonnepanelen op jouw dak Hardware & Software 17
Freddy Beveiliging van jouw PC, gamegear en andere spullen thuis HighFlow Product Suggesties en Nieuws 2
Freddy TP10: HighFlow Casemod Compo, jouw tips aub Lan Party 37
MASTERBLASTER H70 hoe heet wordt jouw CPU?? Waterkoeling 10
l3p Hoelang doet jouw Windows 7 erover om te restarten ? Benchmarks & Scores 113
F wat zijn jouw beste wensen voor 2011 Algemene Discussies 8
Freddy HighFlow Polo Shirts met jouw Nickname, hier bestellen :) Lan Party 164
Freddy Discussie Topic: Waar is jouw HighFlow sticker? HighFlow Computer Cooling Shop 89
Freddy Contest: Waar is jouw HighFlow Sticker??? Win prijzen! HighFlow Computer Cooling Shop 30
Freddy Test Topic, voor jouw avatar, handtekening, nieuwe opties, etc. HighFlow Forum 31
l3p Hoe ziet jouw schijvenpark er uit ? Algemene Discussies 66
Baloo.be Hoeveel Liter Water gaat er in jouw Setup? Waterkoeling 32
HighSpeed^ Het Universum / Heelal - Jouw Mening Algemene Discussies 77
Issieee De grote STEAM topic, jouw ervaringen met STEAM Gaming 43
K Pi scores in jouw favoriete spel shoppen Overclocking 1
Mobomonster Foto van jouw huisdier! Algemene Discussies 384
D [Fans] Welke heb je op jouw radiator? Waterkoeling 15
Freddy Post jouw Snap Shots met jouw (mobile) camera Algemene Discussies 30
maomanna Jouw internetsnelheid Algemene Discussies 451
Freddy [PC] Jouw droom configuratie op het moment Hardware & Software 3
P Jouw Temperaturen Waterkoeling 24
DieHard gaat de kracht van een fan acheruit met een splitter? Overige Koeling 6
