Pharlap
0. Volledige naam van het product?
Innovatek AGB-O-Matic - Eheim 1046/1048 Reservoir Blue
Ongeveer 6maanden geleden
Niet lang, alleen mee gestest
Andere setup
Ja, moet ik nog opzoeken
Nieuw
nvt
7. Wat is je richtprijs?
Vraagprijs:€ 15,-
The AGB-o-Matic simplifies filling and ventilation of a water cooling system. It is attached directly to the EHEIM pumps and makes a water holding reservoir, from which the pump can suck in directly and air-free. This tank's internal design makes for extremely efficient air bubble removal.
Despite the compact design of 50x56x120mm (lxbxh) it makes a large volume of water available.
The water cooling system is filled after the assembly by the opening at the top side (yellow screw cap)
The AGB o Matic consists of extremely sturdy special plastic, is very compact and optimally coordinated with the Eheim 1046 and 1048 pumps (won't fit other Eheim models). Mates water-tight to the pump's intake stem via two rubber O rings.
The water return is equipped with a standard 8mm compression fitting.
Technical data:
Weight: 110g
Material: high-strength special plastic
Size (without pump): (lxbxh) 50x56x120 mm
suitably for EHEIM 1046 and 1048
Andere setup
Nieuw
nvt
Vraagprijs:€ 15,-
Technical data:
Weight: 110g
