Productomschrijving Correcties
Het lijstje compatible koelblokken voor dit link stukje is wat langer geworden:
EK-FC Link R48X0/58X0
VERY IMPORTANT:
FC Links cannot be combined together, as it was physically impossible to construct all to line-up. Meaning you can only use EK-FC Link R48X0/58X0 in one setup without combining them with other two Link options.
High quality connecting link for your favorite waterblocks.
Link is made of high quality POM Acetal.
Please note that link is not a standalone unit and needs to be used with one of EK-FC Bridge series to make it fully functional.
You need one FC LInk piece for one FC Block.
Link is compatible with:
- EK-FC4850/4870
- EK-FC4890
- EK-FC4890 LT (only compatible with TL blocks together because of block thickness)
- EK-FC5850
- EK-FC5870
Included:
- FC Link part
- 4 o-ring gaskets
- all mounting screws comes with EK-FC Bridge part
EK-FC Link R48X0/58X0 - FC Bridges & Links - VGA Blocks - Blocks
EK-FC Link R48X0/58X0 is a high quality connecting link adapter for connecting your favorite EK Full-cover waterblocks to the EK-FC Bridge multiblock (dual, triple or quad) interconnect.
Please note that link itself is not a standalone unit and needs to be used with EK-FC Bridge series interconnect to make it fully functional.
You need one FC Link adapter for each FC water block you wish to connect.
EK-FC Link R48X0/58X0 is compatible with the following FC waterblocks:
- EK-FC4850/4870
- EK-FC5850
- EK-FC5870
- EK-FC5870 MSI
- EK-FC5870 V2
- EK-FC5870 ASUS V2
- EK-FC6870
- EK-FC6970
- EK-FC6970 V2
- EK-FC6990
- EK-FC7970
- EK-FC460
- EK-FC460 GTX GS/SONIC
Included:
- 1x EK-FC Link GeForce
- 4x O-ring gaskets
Mounting mechanism is not included since it comes with every EK-FC Bridge part.
VERY IMPORTANT:
Dan dat andere link stukje ook maar even. :)
EK-FC Link GeForce HighFlow
EK-FC Link GeForce EKWB
EK-FC Link GeForce is a high quality connecting link adapter for connecting your favorite EK Full-cover waterblocks to the EK-FC Bridge multiblock (dual, triple or quad) interconnect.
EK-FC Link GeForce is compatible with the following FC waterblocks:
- EK-FC285 GTX
- EK-FC 285 GTX PCB V2
- EK-FC275 GTX
- EK-FC285 GTX EVGA Classified
- EK-FC470 GTX
- EK-FC480 GTX
- EK-FC580 GTX
- EK-FC5x0 GTX GW
- EK-FC560 GTX V2
- EK-FC570 GTX SE
- EK-FC580 DCII
- EK-FC590 GTX (needs longer screws due to having thicker top)
Included:
- 4x O-ring gaskets
Omschrijving van Arctic Alumina Silver Thermal Adhesive is niet correct en de daarbij behorende product omschrijving, het is Arctic Silver™ Thermal Adhesive of Arctic Alumina™ Thermal Adhesive.
De Alumina is niet electronisch geleidend en de Silver beperkt:
Pure Electrical Insulator:
Arctic Alumina Adhesive is a pure electrical
insulator, neither electrically conductive nor capacitive.
Arctic Silver Thermal Adhesive was formulated to conduct heat, not electricity. NOTE: Even though Arctic Silver Thermal Adhesive is specifically engineered for high electrical resistance, it should be kept away from electrical traces, pins, and leads. The cured adhesive is slightly capacitive and could potentially cause problems if it bridged two close-proximity electrical paths.
Bron: arctic website
Oh ok, ik dacht meer dat het zo iets moest zijn:
http://www.watercoolinguk.co.uk/images/product_images/large/molex-female-pins.jpg
Soortgelijke zoek ik.
Deze zijn van die stekkers aan de zijde van de voeding (modulair).
(ah nu zie ik het, het staat ook in de beschrijving:"These Pins complete the male PSU power connector")
Zoals
VGA Power connector Pins for Sockets/Female - 20 stuks
en
ATX Power connector Pins for Sockets/Female - 20 stuks
Mijn berichtje hoort dan misschien meer in product suggesties:eusa_whistle:
nog een linkje:link naar gammods
XSPC RayStorm CPU WaterBlock Intel - XS-RAYS-INT
Supplied with mounting hardware, 775, 1156/1155, and 1366 backplates, twin blue LED, allen key, and K2 thermal paste.
Bij de review knop vermeld iemand ook dat de 2011 mounting kit ontbreekt en moet worden aangeschaft.
Nou heb ik laatst de waterblock besteld en de mounting kit ernaast, alleen kreeg ik een email dat de mounting kit er al bij zat en ik waardepunten op mijn account kreeg gestort.
Alhoewel de review outdated is toch even de artikel info/review aanpassen?
Ik heb mijn bestelling nog niet binnen :088: (zondag)
