Nollie ARGB Controllers, Nollie1, Nollie8, Nollie16 en Nollie32
SeaShark
- Nollie16
- Nollie
- Illuminate your PC with the Nollie 16 ARGB Controller. This powerful hub expands your RGB lighting possibilities, allowing you to connect and control up to 16 ARGB components. Create stunning light shows and synchronize your entire setup with ease.
HARDWARE PARAMETERS
  • USB: High Speed
  • Channel: 16 Channels
  • Single Channel Driver: 256LED
  • Power: 2x Molex
  • Protection: 15A Fuse
    INTERFACES
  • ARGB 5V3Pin x16
    SOFTWARE
  • SignalRGB
  • OpenRGB
    PACKAGE CONTENT
  • ARGB Controller(Nollie16) x1
  • 5V 3-pin Female to Male adapter x16
  • USB 2.0 Internal Motherboard connector to USB PH2.0 cable (50cm) x1
  • XT30 to 2x Molex x1
    SPECIFICATIONS
  • Model: Nollie16
  • Dimensions: 114.8×32.5×12mm
- https://nolliergb.com/our_products/nollie-16/
- https://nolliergb.cn/products/nollie16
- https://nl.aliexpress.com/item/1005...644637&gatewayAdapt=glo2nld#nav-specification
Slader Singularity Computers Multi-Node ARGB+Fan? Waterkoeling 3
dess Lamptron LAMP-FARGB PWM/ARGB hub. HighFlow Webshop 1
sir serial Argb - Drgb hub hub hub heeelp!! Cases en Modding 2
Bl4ckj4ck666 Argb hub zalman Cases en Modding 8
J Argb devices individueel aansturen Electronica 1
Jason Gelid Solutions Amber5 ARGB Controller HighFlow Product Suggesties en Nieuws 0
Jason Gelid Solutions Astra ARGB Extension Cables HighFlow Product Suggesties en Nieuws 0
Jason Noiseblocker NB-eLoop X B12-PS ARGB - 120mm - Black HighFlow Product Suggesties en Nieuws 0
Slader noiseblocker NB-ELOOP X B12-PS ARGB BLACK EDITION - 120MM HighFlow Product Suggesties en Nieuws 1
Jason Gelid Solutions Stella - 120mm ARGB Fan HighFlow Product Suggesties en Nieuws 0
Hightower 3pin ARGB / DRGB verlengkabel. HighFlow Product Suggesties en Nieuws 14
Freddy Gelid Solutions 6-Channel Programmable ARGB Controller Kit HighFlow Product Suggesties en Nieuws 0
L ARGB Verloop?! Cases en Modding 2
Jason Brook Powerbay Portable and Fast Charging Stand, Docking for Switch, Compatible with Switch and GC Controllers, Support HDMI Output HighFlow Product Suggesties en Nieuws 4
ABRAWARE Compitabiliteit LED controllers RGB Handleidingen en Installatie Tips 8
Freddy Aqua-Computer Farbwerk RGB controllers en ledstrips HighFlow Product Suggesties en Nieuws 11
Freddy RAID controllers in de aanbieding! HighFlow Computer Cooling Shop 2
Freddy Nieuwe Lamptron Fan Controllers: FC9, CM615, CF525, FC2 HighFlow Product Suggesties en Nieuws 2
3 [IN-ACTIVE] Unieke Lian Li Hitman Mod incl Feser Monsta Rad en MCubed Controllers. Verkocht 13
dave-firsttimer:) Advies over Fan Controllers Cases en Modding 19
D Verschil controllers ? Overige Koeling 3
