Nanoxia PWMX Control Module
WiSK
Hoi Freddy. Graag deze in de winkel :)
Naam product
PWMX Control Module
Naam fabrikant
Nanoxia
Link
http://www.nanoxia-world.com/zubehor/pwmx/pwmx-control-module.html
Omschrijving
The Nanoxia 3-Pin to 4-Pin PWM fan controller is a unique adapter that allows you to plug any standard 3-Pin fan into your PWM motherboard and have your motherboard control your standard fan as if it were a PWM fan! The Nanoxia PWMX does this by the Nanoxia controller chip that detects the connected fan and generates the fitting PWM characteristic; enabling every 3-Pin 5-12V fan to be accessed by PWM enabled motherboards. The Nanoxia PWMX also has a manual rheostat onboard so you can even further fine tune your fans speed.
Features:
•PWM motherboard control for any 3-Pin fan!
•Manual rheostat for further fine tuning
•Black sleeved cables
•Installs in seconds
Specifications:
•Dimension: 3.2 x 1.2 x 1.3 cm
•Voltage range: 5V - 12V
•Input connector: 4-Pin PWM (to motherboard)
•Output connector: 3-Pin fan connector
Foto
EAN code
4260285292439
Hightower Nanoxia Coolforce CF1 koelvloeistof HighFlow Product Suggesties en Nieuws 5
T Alphacool plexi light module en nanoxia 120mm pwm HighFlow Product Suggesties en Nieuws 2
S Nanoxia X EVO 120 mm IFC - 1600 RPM HighFlow Product Suggesties en Nieuws 5
R Nanoxia FX12–1250, 120mm HighFlow Product Suggesties en Nieuws 3
M [IN-ACTIVE] Nanoxia 120mm FX12 - 1250 Gevonden 0
M Nanoxia 120mm FX12 - 1250 HighFlow Product Suggesties en Nieuws 7
animal baars Nanoxia FX08 HighFlow Product Suggesties en Nieuws 2
AzzKickr Nanoxia fans Overige Koeling 11
Edtje Nanoxia fans HighFlow Product Suggesties en Nieuws 13
LightStar Nanoxia 120mm 600rpm en 140mm 700rpm HighFlow Product Suggesties en Nieuws 20
1 Nanoxia Fans HighFlow Product Suggesties en Nieuws 3
M control 18 fans Overige Koeling 4
S aquastream xt speed control ? Waterkoeling 0
X fan 3 pin of 4 pin voor radiatoren en fan control Waterkoeling 17
Zwelgje [GEVONDEN]Saitek PRO Flight X-65F Combat Control System HOTAS Gevonden 1
S Antec 600 fan control Overige Koeling 3
pilotter fan control Overige Koeling 14
I Meerdere vragen betreft water koeling en fan control Advies Waterkoeling Setup 10
Skydrone D-RAM timing control Overclocking 5
Freddy Iandh Power Control Panel HighFlow Product Suggesties en Nieuws 32
aadje93 CCFL sound/geluid control maken ??? Cases en Modding 15
R 4pin fan control op mobo Hardware & Software 6
