Sw333t
I Love my NUC
Freddy, kan deze in de shop toegevoegd worden: Lamptron Fan-Atic: 5-port.
The baybus allows you to be in control! It controls up to 60Watt per channel with 3 different voltage output and 5 channels can be used for any controls. CNC milled faceplate and drilled mesh will bring you cool looks and functions to your solid cases.
Specifications:
Dimension: 5.25" Bay
Max Power: Up to 60W per Channel
Adjustment Range: (5V Off 12V), (7v Off 12v) please read the retailer's description to make sure of type
Color Available: Black Anodized Aluminum, Plain Aluminum Finish
Features:
LED Voltage Indicator (12v-Red 5v-Blue or 12v-Red 7v-Blue)
Control up to 60W Per Channel
5 Independant 3 Way Adjustment Range Military Switches
Mesh Design to Match Mesh Cases
De versie die ik zou willen is de versie die kan schakelen tussen 7v - Off - 12v.
Specifications:
Features:
