Lamptron CW611
SPECIFICATIONS:
Dimension: 148.5mm*42.5mm*63mm(5.25″ Bay)
LCD Dimensions: 118mm*31mm
Power Output: Up to 36 watts per channel
Control Channel: 6 Channels (All usable in pump, flow meter or fan control mode)
Panel Color Available: Black Anodyzed / Silver
DC Input: +12v (Standard 4 Pin Molex / “D” Connector)
DC Output: 0V- 12V DC
Connectors: 6 X 2510-3pin connectors
Recommend PSU wattage: 550w or higher
FEATURES
Improved Extra Large LCD
Customizable Channels for Air and Water Cooling
Fully Compatible with Fans, Pumps (up to 12v) and Flow Meters
Full Flow Number Readout Display/li>
Reverse Power & Overvoltage Protection
MSRP: $89.99 // 69.99€
LINK
A Fancontroller Lamptron CW611 Waterkoeling 3
A Lamptron FCT CW611 HighFlow Product Suggesties en Nieuws 6
Jason Lamptron HM173 Portable Display for AIDA64 - 17.3" IPS, HDMI, Ultra-thin narrow edge/bezel HighFlow Product Suggesties en Nieuws 0
Jason Lamptron HM088 PC Hardware Monitor/Display for AIDA64 - 8" IPS, HDMI, Widescreen HighFlow Product Suggesties en Nieuws 0
Freddy Lamptron HM070, HM101, HM173 Portable Display for AIDA64 HighFlow Product Suggesties en Nieuws 39
Freddy 10% korting op Lamptron LED strips! t/m 29 april 2018 HighFlow Computer Cooling Shop 0
DuctTape Lamptron FC10 HighFlow Product Suggesties en Nieuws 2
Freddy HighFlow 2014 Sinterklaas Kado's! Gratis verzending, 10% korting op ProAce + Lamptron HighFlow Computer Cooling Shop 0
M Leds van waterblokken en D5 Pomp + Lamptron Touch Waterkoeling 12
Freddy Nieuwe Lamptron Fan Controllers: FC9, CM615, CF525, FC2 HighFlow Product Suggesties en Nieuws 2
cederieck Lamptron fc 8 is dit moogelijk ? Electronica 2
S Lamptron Blue and White Dual Color LED HighFlow Product Suggesties en Nieuws 9
B Lamptron Claw Clamp HighFlow Product Suggesties en Nieuws 2
H hoeveel fans op een lamptron fc5 4x30w Overige Koeling 4
J Lamptron 4-port Black Anodized Aluminum Casing CCFL Inverter Cases en Modding 6
O Lamptron 22mm vandal switch HighFlow Product Suggesties en Nieuws 4
J Lamptron FC9 HighFlow Product Suggesties en Nieuws 2
TYPHOON Lamptron Vandal Switch Cases en Modding 2
S Lamptron FC5 v2 Overige Koeling 2
S Lamptron Fan-Atic: 5-port HighFlow Product Suggesties en Nieuws 4
Lykele87 Lamptron FC5V2 HighFlow Product Suggesties en Nieuws 3
Skydrone lamptron hummer military fancontrol HighFlow Product Suggesties en Nieuws 7
K Vandal switch op een lamptron cffl inverter plaatsen Handleidingen en Installatie Tips 23
W Lamptron moddingtool kit in envelop HighFlow Webshop 1
W Sleeving tool kit Lamptron of Sunbeam? Cases en Modding 7
H Lamptron FCT HighFlow Product Suggesties en Nieuws 43
Source Lamptron Producten, o.a. Noise Isolation Strip HighFlow Product Suggesties en Nieuws 71
W Lamptron cable holder HighFlow Product Suggesties en Nieuws 4
Colossus Lamptron FC-5 Fan Controller HighFlow Product Suggesties en Nieuws 18
Busterben lamptron spul HighFlow Product Suggesties en Nieuws 2
ShaquilleMoreno Lamptron Fan Controller(FC-2) HighFlow Product Suggesties en Nieuws 3
