The Fractal Design Define R4 is the latest in the Define Series of computer cases offering minimalistic and stunning Scandinavian design fused with maximum sound reduction, configurability and functionality.
Now featuring the option to have your Define R4 case with a large fully transparent window allowing you to display your setup in style.
The acrylic window side panel features the same clean, Scandinavian design as the case itself, and has a completely flat outer surface without any plastic bezel or rivets.
Key Features
■High density noise-reducing material lining acrylic window
■Patent pending ModuVent™ design allowing the user to choose between optimal silence or maximum airflow
■Top HDD cage (5 trays total) can be rotated 90 degrees or removed for additional airflow or to accommodate long graphic cards up to 430mm in length
■Three-speed fan controller is strategically integrated in the front panel and supports up to 3
fans
■Two Silent Series R2
fans included, featuring hydraulic bearings contributing to a longer life expectancy – Silent Series R2 retail
fans will now come standard in all cases
■Wider case body that allows for improved cable routing behind the motherboard – now 26mm wide
■New tool-less front fan holder makes switching front
fans a breeze
■Two SSDs can be mounted on the back of the motherboard plate in addition to the 8 slots in the HDD trays, for a total of 10 SSD positions available
Technical specifications
■ATX, Micro ATX, Mini ITX motherboard compatibility
■7 + 1 expansion slots
■2 - 5.25" bays
■8 - 3.5" HDD trays - all compatible with SSDs, 2 - 2.5" extra SSD positions
■2 - ModuVent™ plates - two in the top and one in the side
■6 - fan positions (2 Silent Series R2
fans included)
■Filtered fan slots in the front and bottom
■CPU coolers up to 170mm tall
■ATX PSUs up to 170mm deep when using the bottom fan location, when not using this fan location longer PSUs (up to 270mm deep) can be used
■Graphics cards up to 295mm in length with the top HDD cage installed
■With the top cage removed, graphics cards up to 430mm in length may be installed
■26mm of space for cable routing behind the motherboard plate
■Thick rubber grommets on all holes on the motherboard plate
■Colours available: Black Pearl, Titanium Grey, Arctic White
■Case dimensions (WxHxD): 232 x 464 x 523mm
■Package dimensions (WxHxD): 320 x 535 x 610mm
■Net weight: 12,3 kg
Cooling / ventilation
■ 1 - Front hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed (included)
■1 - Front 120/140mm fan
■1 - Rear hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed (included)
■2 - Top 120/140mm
fans - positions also support some models of 240mm radiators, depending on configuration
■1 - Bottom 120/140mm fan
■1 - Integrated fan controller for up to 3
fans (included)
Front interface
■2 - USB 3.0, 2 - USB 2.0
■Audio I/O
■Power button with LED (red)
■Reset button
■Fan controller (behind door)
Retail package content
■Define R4 - Window computer case
■User manual
■Accessory box
Additional Information
■EAN/GTIN-13: 7350041081036
■UPC: 817301011037
■Product code: FD-CA-DEF-R4-WH-W
