EK Ectotherm thermal compound
EK introduces Ectotherm thermal compound in 5g packaging
EK Water Blocks, Ljubljana based premium computer liquid cooling gear manufacturer, is proud to introduce EK-TIM Ectotherm in retail packaging. The very same thermal compound, previously only available when bundled with EK Full Cover water blocks, is now available for separate purchase in a practical 5g dose.
EK-TIM Ectotherm is a best in-class thermal compound with exceptional value for money. This thermal interface material provides an effective heat transfer and easy application between CPU, GPU or any other PCH/chipset and heat sink.
Ectotherm has been bundled with EK Full Cover water blocks since early 2013 and has been deployed by various system integrators as a cost effective, yet high performance thermal compound.
This Low Viscosity and Electrically Non-Conductive thermal compound makes each application trouble-free and failsafe.
EK-TIM Ectotherm comes in a practical five grams (5g) packaging within a reusable gitf-box and is thus a perfect choice for passionate computer modders, overclockers and computer repair shop personel.
Features:
- High Thermal Conductivy
- Low Thermal Resistance
- Low Viscosity
- Non-Capacitive and Electrically Non-Conductive
- Non-Corrosive and Non-Curring
- No Bleeding & User Friendly
Technical specifications:
- Density (g/cm3): 3.0
- Net Content (g): 5.0
- Thermal conductivity (W/mK): 8.5
- Optimal working temperature (°C): +100 to -50
Made in China for EK Water Blocks.
EK-TIM Ectotherm comes with a MSRP of 4.95€ (incl. VAT) and is readily available for purchase through EK Webshop as well as Partner Reseller Network.
Wanneer kunnen we deze verwachten? :D
Boemelke iChill 1080TI X3 thermal pads / paste Overige Koeling 11
Jason Gelid Solutions GP-Ultimate lijn Thermal Pads HighFlow Product Suggesties en Nieuws 0
Bl4ckj4ck666 Thermal pads HighFlow Product Reviews 0
Jason Thermal Grizzly - Remove 10ml & Shield 5ml HighFlow Product Suggesties en Nieuws 1
Jason Thermal Grizzly Kryonaut Extreme - 2G HighFlow Product Suggesties en Nieuws 0
volcom GELID Solutions GC Extreme Thermal Compound 3.5g HighFlow Product Suggesties en Nieuws 3
Freddy Fujipoly Thermal pads, professionele thermal pads nu beschikbaar bij HighFlow HighFlow Product Suggesties en Nieuws 1
A Thermal Pads vervangen Overige Koeling 3
stigma Beste Thermal pads Overige Koeling 1
B thermal compound Waterkoeling 2
jev09 Thermal pads Waterkoeling 1
Tath Test thermal compound (Artic Silver 5 e.d.) Handleidingen en Installatie Tips 3
A Thermal Compound Shoot out! HighFlow Product Reviews 6
Legendary1985 [GEVONDEN] Thermal PAD 1mm Gevonden 1
Thierry [IN-ACTIVE] Thermal adhesive tape Gevonden 0
R Thermal Pads folie/beschermlaag verwijderen? Waterkoeling 2
J Thermal pad ramp Waterkoeling 2
M Indigo Xtreme Thermal Interface HighFlow Product Suggesties en Nieuws 8
BETA911 [INACTIVE] Swiftech MCRES-Micro + thermal pads... Gevonden 6
arwin74 Thermal Pad HighFlow Product Suggesties en Nieuws 3
Sparky Installatie Koolance Chipset blok: Welk thermal stripje moet waar?? Waterkoeling 3
P Non Conductive Thermal Paste nodig for GPU waterblok??? Waterkoeling 3
P Zalman Thermal Adhesive HighFlow Webshop 4
H Ek Thermal Pad 1mm HighFlow Product Suggesties en Nieuws 14
Miesepies Thermal pad / spacer HighFlow Product Suggesties en Nieuws 1
