Drive bays en Watercool MO-RA3 4x180 LT radiator
andreas
Goedenavond!
Zijn volgende producten te bestellen/verkrijgen bij highflow?
Die laatste 2 zijn ook te vinden in een andere shop. Maar ik bestel liever bij highflow.(.,)
5 x 5.25 optical drive cage Mountainmods
Fabrikant
Mountain Mods 5 x 5.25 inch optical drive cage will hold up to 5 optical devices. This can be installed in any Mountain Mods front or back panel that incorporates a 5 bay cutout or can be used as an easy drive bay solution for the do it yourself type.
The drive cage is completely modular and comes flat packed. 4 tapered 6-32 screws are included for fastening side walls to the 5.25 frame.
120mm Hard drive rack Mountainmods
Fabrikant
Mountain Mods innovative 120mm Hard drive rack can be used to add up to 3 hard drives to any 120mm system fan. Attaching directly to the fan allows for MAXIMUM airflow. Never worry again about your drives getting too hot. The shroud like design forces air directly through the drives resulting in superb heat removal. Use up to 6 sets of these for 18 drive capacity in a Mountain Mods U2-UFO or up to 15 Hard drives in the Opti-1203 series chassis. These can also be used in the Twice7 chassis to expand drive capability. The hard drive racks can be used in any case with ample space. The 2 piece rack design allows you to place your drives in Horizontal or Vertical configuration. Mountain Mods Hard drive racks provide you with so many options!
Watercool MO-RA3 4x180 LT black
Fabrikant
Technical specifications:
Material internal: Copper tubes, aluminium fins
Material casing: Coated steel sheet material, brushed stainless steel
Outer dimensions (LxWxH): 415 x 383 x 65mm
Weight: approx. 6000g
Pressure tested: 5 bar
Surface: Black powder coating
Connection threads: 6x G1/4"
Silverstone 180mm fan SST-FN181-BL
Fabrikant
18mm silent fan &blue leds
Jason BarrowCH Heatsink for 2280, 22110 M.2 SSD Hard Drive with OLED Temperature Display HighFlow Product Suggesties en Nieuws 0
U BitFenix Hydra Pro modden in 5.25inch lege optical drive casing Cases en Modding 2
Aequitis [GEZOCHT] 2x toolles drive fastener Coolermaster (CM690) Gevonden 1
R Swiftech Apogee Drive II HighFlow Product Suggesties en Nieuws 33
Xelation [2011] Drive Films / Movies 7
U SilverStone slim type DVD combo optical drive HighFlow Product Suggesties en Nieuws 5
Legendary1985 [GEVONDEN] SPOED Optische drive *defect* gevraagd Gevonden 2
Freddy [2008] Sex Drive Films / Movies 5
Thierry Swiftech MCR Drive HighFlow Product Suggesties en Nieuws 2
Busterben slim drive kit HighFlow Product Suggesties en Nieuws 60
Thierry Swiftech Apogee Drive 350 Waterkoeling 10
Thierry Swiftech Apogee Drive 350 Waterkoeling 0
Sw333t [VERKOCHT] Hot swap bays (officieel bedoeld voor een Cooler Master HAF X) Verkocht 10
HighFlow Watercool MO-RA IV Radiatoren HighFlow Product Suggesties en Nieuws 0
Jason Watercool HEATKILLER V for RTX 3080/3090 HighFlow Product Suggesties en Nieuws 0
Jason Watercool HEATKILLER V for RX 6800/6900XT HighFlow Product Suggesties en Nieuws 0
G Watercool VRM cooling DYI HighFlow Product Suggesties en Nieuws 5
F Correcte afmeting Watercool Heatkiller GPU (DIY) blok) Waterkoeling 3
B Happy Watercool hear! Introductie: Stel jezelf en jouw PC voor 9
Thierry Watercool gpu-x blok HighFlow Product Suggesties en Nieuws 5
coolfris [VERKOCHT] 2x Watercool HEATKILLER GPU-X3 GTX 780-TITAN "Hole Edition" + Backplates Verkocht 2
R Watercool HEATKILLER® GPU Backplate 79X0 HighFlow Product Suggesties en Nieuws 3
F [IN-ACTIVE] Watercool Heatkiller GPU-X³ 5X0 "Hole Edition" Verkocht 0
D Watercool systeem. Advies Waterkoeling Setup 1
Asphiax Watercool HEATKILLER NSB Rev3.0 Ni Northbridge / Southbridge (Nickel Plated) edition HighFlow Product Suggesties en Nieuws 3
Y Watercool HTF4 Radiator HighFlow Product Suggesties en Nieuws 3
ThomasJS [CANCELLED] Watercool HeatKiller Rev3 S1366 + Backplate Verkocht 8
Y Watercool HeatKiller HK3.0 Socket 2011 retention bracket HighFlow Product Suggesties en Nieuws 3
S [IN-ACTIVE] Watercool heatkiller 3.0 am2/am3/am3+ Verkocht 0
W Watercool MO-RA3 420 Grill Rhombus Black HighFlow Product Suggesties en Nieuws 1
A Mijn eerste watercool project met k en 3x gtx 570 Gallery & Build Logs 9
lauwagie [watercool heatkiller] HighFlow Product Suggesties en Nieuws 1
ben361 Watercool HeatKiller Rev. 3.0 S1156 Black Nickel Chrome HighFlow Product Suggesties en Nieuws 2
T [VERKOCHT] Watercool Heatkiller 3.0 S775+S1156 Verkocht 9
ben361 Watercool HeatKiller Rev. 3.0 S1156 Advies Waterkoeling Setup 10
W Watercool HeatKiller 6850LT Waterkoeling 5
Legendary1985 Watercool MO-RA3 9x120/9x140 HighFlow Product Suggesties en Nieuws 9
Edtje Watercool MO-RA3 Pro Toebehoren HighFlow Product Suggesties en Nieuws 13
thiesggb watercool heatkiller LC 1366 Verkocht 6
