Mother Board BP Block Model
MSI X99S SLI PLUS BP-WBBRAGIMIX99FCBNPAC-CL
MSI X99S GAMING 7 BP-WBBALDURMIX99FCBNPAC-CLBK
MSI X99S MPOWER BP-WBHODRMIX99FCBNPAC-CLBK
MSI X99S XPOWER AC BP-WBTYRMIX99FCBNPAC-CL
MSI X99S GAMING 9 BP-WBTHORMIX99FCBNPAC-CL
1.
MSI X99S SLI PLUS
Bitspower BRAGI MIX99 Nickel Plated Full-Covered-Block (Clear)
Features:
1. Design For MSI X99S SLI PLUS.
2. Included CPU/ChipSet and MOS Blocks.
3. Full-Covered-Block Design.
4. Block TOP Cover Made Of Hi-Quality Acrylic.
5. Block Base Made Of Hi-Quality Copper.
6. Block Base High Durability Nickel Finished In Shining Silver.
7. Polished Stainless Panel In Matt Black.
8. RoHS Compliant.
Dimension ( LxWxH ) : 285.1x152.5x49mm
Thread : G1/4" x 2
Included :
1. MIX99SP Full-Covered Armor (Clear) x 1 PCS.
2. BP-MBWP-C90 x 6 PCS.
3. MIX99SP Nickel Plated (Clear) x 1 Set.
4.
CPU Block Summit EF (Intel) (Acrylic Top Version) x1 Set.
5. Backup O-Ring x 1Set.
6. Thermal PAD Included.
7. Mounting Screws/Accessories.
Compatibility :
MSI X99S SLI PLUS
2.
MSI X99S GAMING 7
BP-WBBALDURMIX99FCBNPAC-CLSL
Bitspower BALDUR MIX99 Nickel Plated Full-Covered-Block (Clear/Silver)
Features:
1. Design For MSI X99S GAMING 7.
7. Polished Stainless Panel In Shining Silver.
8. RoHS Compliant.
Dimension ( LxWxH ) : 227.6.4x152.9x49MM
Thread : G1/4" x 2
Included :
1. BALDUR MIX99 Full-Covered Armor (Clear) x 1 PCS.
3. BALDUR MIX99 Nickel Plated (Clear) x 1 Set.
4.
3.
MSI X99S MPOWER
Bitspower HODR MIX99 Nickel Plated Full-Covered-Block (Clear/Black)
Features:
9. Design For MSI X99S MPOWER.
10. Included CPU/ChipSet and MOS Blocks.
11. Full-Covered-Block Design.
12. Block TOP Cover Made Of Hi-Quality Acrylic.
13. Block Base Made Of Hi-Quality Copper.
14. Block Base High Durability Nickel Finished In Shining Silver.
15. Polished Stainless Panel In Matt Black.
16. RoHS Compliant.
Dimension ( LxWxH ) : 270.4x152.9x49 MM
Thread : G1/4" x 2
Included :
8. HODR MIX99 Full-Covered Armor (Clear) x 1 PCS.
9. BP-MBWP-C90 x 6 PCS.
10. HODR MIX99 Nickel Plated (Clear) x 1 Set.
11.
12. Backup O-Ring x 1Set.
13. Thermal PAD Included.
14. Mounting Screws/Accessories.
4.
MSI X99S XPOWER AC
Bitspower TYR MIX99 Nickel Plated Full-Covered-Block (Clear)
Features:
17. Design For X99S XPOWER AC.
18. Included CPU/ChipSet and MOS Blocks.
19. Full-Covered-Block Design.
20. Block TOP Cover Made Of Hi-Quality Acrylic.
21. Block Base Made Of Hi-Quality Copper.
22. Block Base High Durability Nickel Finished In Shining Silver.
23. Polished Stainless Panel In Matt Black.
24. RoHS Compliant.
Dimension ( LxWxH ) : 276.7x210x49 MM
Thread : G1/4" x 2
Included :
15. TYR MIX99 Full-Covered Armor (Clear) x 1 PCS.
16. BP-MBWP-C90 x 6 PCS.
17. TYR MIX99 Nickel Plated (Clear) x 1 Set.
18.
19. Backup O-Ring x 1Set.
20. Thermal PAD Included.
21. Mounting Screws/Accessories.
5.
MSI X99S GAMING 9
Bitspower THOR MIX99 Nickel Plated Full-Covered-Block (Clear)
Features:
25. Design For MSI X99S Gaming 9.
26. Included CPU/ChipSet and MOS Blocks.
27. Full-Covered-Block Design.
28. Block TOP Cover Made Of Hi-Quality Acrylic.
29. Block Base Made Of Hi-Quality Copper.
30. Block Base High Durability Nickel Finished In Shining Silver.
31. Polished Stainless Panel In Matt Black.
32. RoHS Compliant.
Dimension ( LxWxH ) : 279.8x200x49 MM
Thread : G1/4" x 2
Included :
22. THOR MIX99 Full-Covered Armor (Clear) x 1 PCS.
23. BP-MBWP-C90 x 6 PCS.
24. THOR MIX99 Nickel Plated (Clear) x 1 Set.
25.
26. Backup O-Ring x 1Set.
27. Thermal PAD Included.
28. Mounting Screws/Accessories.
