Yate Loon D12SL-124UB
rberbers
- Naam: Yate Loon D12SL-124UB UV-Blue met blaue LEDs & aansluiting (1350rpm) (120x120x25mm)
- Omschrijving: New fan from Yate Loon. Strong airflow and super-quiet operation speak for this 120mm axial fan with a bronze bearing. The fan can be connected to the PSU via a Molex plug (with adaptor, sold separately) or directly to the Mainboard. The fan is ideal for the super silent operation when operated at <7V. Thanks to the extra long connection cable of approx. 60cm th fan can also be used in very large cases (e.g. Server or Big-tower) and still be properly wired without using cable extensions.
The fan is an absolute highlight for modders! The blue LEDs give a unique touch to any case. The transparent frame allows the fan to look just like any other fan in daylight, but in the dark it will reveal its feature when in operation! Also the frame of this fan is UV-reactive and lights up when lit with UV-light.
- Specificaties:
Technical data:
Dimensions: 120x120x25mm
Nominal voltage: 12V
Nominal speed: 1350 rpm
Airflow: 46 CFM
Power consumption: 3,6W
Noise level: 23 dB(A)
With 3-pin plug, approx. 60cm cable and rpm signal
Fabrikant URL
HighFlow.nl product pagina
Volgens mij is dit praktisch dezelfde fan als de populair D12SL-12, alleen deze reageert op UV licht. Kunnen jullie deze ook leveren?
