Good Quality version of 120mm Yate-Loon D12SL-12 fans
tonschk
Many months ago I bought some Yate-Loon 120mm D12SL-12 Black fans , Impressive Extreme and unbeliveable quiet and silent were this Yate-Loon D12SL-12 black fans , therefore I add another of this Yate-Loon D12SL-12 120mm to my last order , I was shocked to hear a buzzing/electronic noise coming from this new D12SL-12 120mm black fan , and because I already am aware of this kind of problem , went direct to check if this fan have or not the two small capacitors on the small PCB of the motor , nothing , no one capacitor there , I want to make another order of this Yate-Loon D12SL-12 black fans but I dont know if I will be enough lucky to get again the good quality version of this Yate-Loon black fans with small capacitors on the PCB , therefore I ask you please if is possible for you to check if you have still in stock the good quality version of this D12SL Black fans ( with the capacitors ), it is easy to check if the fan have the two capacitors on the PCB ,therefore is NOT necessary to remove the propeller , you only need to see in the slot between the blades and the frame/shroud of the fan if there are small capacitors, I added photos below , you can see if the fan have or not the capacitors without the need of remove the propeller , thank you very much.
The good quality version of this D12SL-12 black fans were shipping with just a beige colour cartboard ( see photos )
NOISY version of Yate-Loon D12SL-12 Black fan WITHOUT capacitors
Better quality VERSION of Yate-Loon D12SL-12 WITH CAPACITORS
You Can see in the SLOT between the propeller and the shroud the small capacitor
Hello there, I send message to Yate-Loon asking why some 120mm D12SL-12 black fans are made with capacitors and some are made without capacitors , below I added the answer from Yate-Loon customer support , it is difficult to find this Yate-Loon 120mm with capacitors
Dear Sir,
Thanks for your support of Yateloon FAN.
Regarding the capacitors whether we add it is depend on our customers requirment.
Different costomer has different comments.Someone think the fan even without capacitiors is good enough. and someone is like the one with capacitiors....
We make different fan.Hope you can understand me. Thank you ;)
Jason NZXT H1 V2 (2022 Version) HighFlow Product Suggesties en Nieuws 0
M Aquacomputer Kryographics GTX 980 Acrylic Glass edition, Nickel plated version HighFlow Product Suggesties en Nieuws 5
Tath Bitspower Water TanK Z-Multi Ultra 50/100/150/200/250 (POM Version) HighFlow Product Suggesties en Nieuws 1
Tath Bitspower Water Tank Z-Multi Compact 150/200/250/300 (Black Acrylic Version) HighFlow Product Suggesties en Nieuws 0
Slader Water Tank Z-Multi 150 (Acrylic Version) HighFlow Product Suggesties en Nieuws 2
alain-s Alphacool Plexi lighting module with cover G1/4 - Long Version HighFlow Product Suggesties en Nieuws 1
coolfris kryographics for GTX 780 acrylic glass edition, nickel plated version HighFlow Product Suggesties en Nieuws 4
P [Gezocht] Bitspower Water Tank Z-Multi 250 - Full Clear Acrylic Version BP Gevonden 0
bundymania [Bundymania User Review] 4x 1080 Monster Radiators [English Version] HighFlow Product Reviews 0
Dave-V Far Cry 3 patch could not retrieve version number! Zwaar Frustrerend!!! Gaming 3
psyduck170 (UN)Designs Infinite Pump Bracket -Vertical Version - Black HighFlow Product Suggesties en Nieuws 7
bundymania [Bundymania User Review] 6 Waterblocks for HD7970 - Roundup - ENGLISH Version HighFlow Product Reviews 1
Zwelgje Bitspower X-Station Mini Power-Extension II Female Version HighFlow Product Suggesties en Nieuws 13
X-Tripiot [IN-ACTIVE] Coolermaster Elite 330 All-Black version Met window Verkocht 1
bundymania [Bundymania Review] 10x GTX 570/580 Fullcover Waterblocks - ENGLISH Version HighFlow Product Reviews 0
Zwelgje Bitspower Water Tank Z PLUS - POM Version HighFlow Product Suggesties en Nieuws 4
bundymania [Bundymania User Review] Microcool Benchtable Banchetto 101 Modular - ENGLISH VERSION HighFlow Product Reviews 0
bundymania [User Review] English Version: Primochill Myriad Dual Bay Reservoir D5 - Clear HighFlow Product Reviews 0
thijs2163 Sidepanel HAF 932 AMD version HighFlow Product Suggesties en Nieuws 4
Sw333t Scythe 120MM Slip Stream SLIM 1600RPM SY1212SL12M (1,600 rpm Version) HighFlow Product Suggesties en Nieuws 9
bundymania [Bundymania User Review] English Version: Mora 2 / Mora 3 / Phobya Nova 1080 ! HighFlow Product Reviews 6
Johnny Watercooling selling rules [ENG version] Koeling 0
Johnny Hardware selling rules [ENG version] Hardware 0
arwin74 poweradjust 2 USB, ultra version HighFlow Product Suggesties en Nieuws 7
l3p [INACTIVE] 2 x Bitspower Black Freezer HD-S350 Silver Top (POM Version) Bling Bling ! Verkocht 14
bundymania [ REVIEW ] Swiftech MCP 35X Pump + Reservoir - ENGLISH Version HighFlow Product Reviews 4
bundymania [ Review ] 4x Tecnofront Reservoirs - English Version ! HighFlow Product Reviews 5
bundymania [Review] 22 CPU Waterblocks tested - Roundup ENGLISH Version HighFlow Product Reviews 13
Freddy HighFlow Casebadge Photo Contest! English Version HighFlow Computer Cooling Shop 0
bundymania REVIEW: Quadradiator Roundup - ENGLISH Version ! HighFlow Product Reviews 11
Jason Be Quiet! Light Wings 120mm & 140mm PWM High-speed - Triple Pack HighFlow Product Suggesties en Nieuws 0
Jason Noiseblocker NB-eLoop X B12-PS ARGB - 120mm - Black HighFlow Product Suggesties en Nieuws 0
Slader noiseblocker NB-ELOOP X B12-PS ARGB BLACK EDITION - 120MM HighFlow Product Suggesties en Nieuws 1
Jason Gelid Solutions Stella - 120mm ARGB Fan HighFlow Product Suggesties en Nieuws 0
