Kan jij deze leveren Freddy??
Welcome to www.Kingwin.com: Case Fans
Model: CFY-012LB
120 x 120 x 25 mm long life bearing yellow led case fan
Special high profile fan blades for maximum air flow
Provide excellent ventilation for your PC cases
Design for up to 100,000 hrs life expectancy
High performance
High reliability
3 Pin/4 Pin Connector
Fan Dimension: 120 x 120 x 25 mm
Fan Speed: 950 RPM
Bearing Type: Long life bearing
Noise Level: 19 dB(A)
LED: Yellow
Air Flow: 40 CFM
Rated Voltage:
12 VDC
Operational Voltage: 10.8 – 13.3 V
Weight: 0.25 lbs/ 113 g (unit)
Ook in andere kleuren beschikbaar, maar het gaat mij om deze.
Model: CFY-012LB
High performance
High reliability
Fan Speed: 950 RPM
LED: Yellow
Air Flow: 40 CFM
Rated Voltage:
12 VDC
