EK-Furious Meltemi 120mm x 38mm PWM fans
Als je zoveel mogelijk airflow nodig hebt en je hebt voldoende ruimte in jouw kast, kan je deze 38mm dikke fans van EKWB overwegen:
EK-Furious Meltemi 120 PWM Fan (1200-3500rpm)
EK-Meltemi 120ER Black (500-1800rpm)
The EK-Furious Meltemi 120 is the most extreme EK fan up to date. This 38mm thick extreme high-static pressure radiator cooling fan is designed purely for highest-performance computer liquid cooling systems. Developed in-house on the basis of the renowned EK-Vardar fans, they have a wide PWM range of operation and the highest speed of up to 3500 RPM. Due to a 38mm thick frame, there is space for an upgraded motor and far superior performance compared to any standard 25mm thick fan at the same RPM range.
The best possible performance of the EK-Furious Meltemi 120 fan is achieved in pull mode. Such a regime evens out the airflow through the entire surface of the radiator since the motor hub dead zone effect is lessened. The fan is equipped with a red sleeved cable just to warn off those curious little fingers from getting hurt. Seriously, 3500 RPM is no joke, and you should be extra careful around these fans if they are in operation.
The Meltemi family of cooling fans carries the name of a type of strong, dry northern winds of the Aegean Sea. The name Meltemi is derived from Italian mal tempo meaning "bad weather", while we can say that the EK-Meltemi is "bad news" for high temperatures.
EK-Meltemi high-performance fan
The key characteristics of EK-Furious Meltemi fans are:
High-static pressure - unlike other general-purpose computer cooling fans, the EK-Furious Meltemi fans are built specifically for computer liquid cooling systems, namely radiator cooling. The new 7 fan blade design is optimized for extremely high-pressure built upon a massive motor housed in a 38mm thick frame.
High-quality motor and bearing assembly - New electrical design, and the Dual-Ball bearing with 50.000 hours of lifespan (MTBF) @40C operation ensures uninterrupted operation for years to come. Precise Pulse Width Modulation (PWM) for fan speed adjustment allows performance adjustment on demand.
Sealed-edge fan casing - The classic, yet the effective square shape of the fan casing provides optimal performance in either pull - (suction) or push (pressure) regime without hydraulic losses, thus ensuring the optimal cooling capacity of your liquid cooling radiators. The classic shape of the fan frame also allows easy cable routing while grouping more fans on one radiator. For the best performance, EK recommends using the EK-Furious Meltemi 120ER in pull mode.
Robust design - The EK-Furious Meltemi fans fit subtly into any liquid cooling computer giving it an industrial look based on quality and performance.
Sleeved cable - It comes with a 500mm long, red nylon-sleeved 4-pin PWM cable.
Jason Be Quiet! Light Wings 120mm & 140mm PWM High-speed - Triple Pack HighFlow Product Suggesties en Nieuws 0
Jason Noiseblocker NB-eLoop X B12-PS ARGB - 120mm - Black HighFlow Product Suggesties en Nieuws 0
Slader noiseblocker NB-ELOOP X B12-PS ARGB BLACK EDITION - 120MM HighFlow Product Suggesties en Nieuws 1
Jason Gelid Solutions Stella - 120mm ARGB Fan HighFlow Product Suggesties en Nieuws 0
iSP Alpenföhn Wingboost 2 120mm Blood Red Review (English) HighFlow Product Reviews 0
S Corsair Graphite Series 230T 120mm Fan Orange LED HighFlow Product Suggesties en Nieuws 2
C Corsair Air Series AF120 LED Quiet Edition Wit Twin Pack, 120mm HighFlow Product Suggesties en Nieuws 2
S Template gaten 120mm voor radiator Cases en Modding 4
iSP Alpenföhn WingBoost2 120mm fans suggestie HighFlow Product Suggesties en Nieuws 10
Slader delta 120mm fan HighFlow Product Suggesties en Nieuws 2
Freddy 120mm fans (DeepCool) vanaf 2,95 euro. OP = OP HighFlow Computer Cooling Shop 1
Pharlap [VERKOCHT] 9x Coolink SWiF2-120P, 120mm, 1700rpm, Groen/Grijs Verkocht 7
Rooneys [VERKOCHT] 3x Corsair SP120 Twin Pack, 120mm Verkocht 1
S [VERKOCHT] 2x Cooler Master JetFlo 120mm Black (geen led) Verkocht 4
volcom Aerocool DS Dead Silence Fan 120mm Red HighFlow Product Suggesties en Nieuws 8
S [VERKOCHT] 2x be quiet! Shadow Wings 120mm Mid-Speed Verkocht 2
k.3nny Gezocht: 4x rode ledfans 120mm Gevonden 0
R NZXT FZ 120mm HighFlow Product Suggesties en Nieuws 5
Hightower corsair af series 120mm led. HighFlow Product Suggesties en Nieuws 6
Hightower welke 120mm casefan? Overige Koeling 3
volcom Cooler Master Jetflo 120mm Red HighFlow Product Suggesties en Nieuws 9
T Alphacool plexi light module en nanoxia 120mm pwm HighFlow Product Suggesties en Nieuws 2
S gelid silent slim 120mm pwm HighFlow Product Suggesties en Nieuws 2
coolfris Akasa Viper, 120mm, 1900rpm, Geel HighFlow Product Suggesties en Nieuws 1
l3p [VERKOCHT] 3x Scythe 120MM Gentle Typhoon 3000RPM D1225C12B7AP-29 Verkocht 2
ChillPascal [VERKOCHT] 3x Corsair SP's & Phobya G-Changer 120mm Verkocht 9
sir serial [GEVONDEN] 120mm fans Gevonden 5
M [VERKOCHT] Bitspower reservoir en diverse 120mm fans te koop! Verkocht 2
Joren [IN-ACTIVE]120mm Radiator, EK supreme, Fittingen Verkocht 7
Joren [IN-ACTIVE] 120mm radgrill Gevonden 7
Joren [IN-ACTIVE] 120mm radiator, cheap. Gevonden 1
Legendary1985 [GEVONDEN] 120MM fan Gevonden 1
G Akasa Apache 120mm ---> 80mm HighFlow Product Suggesties en Nieuws 1
l3p [VERKOCHT] 3 x Scythe Gentle Typhoon D1225C12B4AP-14 (1450 rpm) 120mm Verkocht 1
l3p [VERKOCHT] 5 x BitFenix Spectre Pro Led Red 120mm Verkocht 4
l3p [VERKOCHT] 3 x Cooler Master V6GT 120mm Verkocht 1
T 120MM Fan Grill? HighFlow Product Suggesties en Nieuws 3
maomanna [GEVONDEN] Scythe Slim Slipstreams 120mm Gevonden 2
BlaserR93 Fan NoiseBlocker eLoop S-Series 120mm HighFlow Product Suggesties en Nieuws 3
Luculenus [CANCELLED] Cooler Master 120MM Excalibur 2000RPM PWM Verkocht 1
l3p [IN-ACTIVE] Diverse Bitspower 120mm & 140mm Fan & Rad Guards Verkocht 3
