volcom
- Naam product
Aerocool Dead Silence 120mm Red
- Naam fabrikant
Aerocool
- Omschrijving product
1. One of world’s most Silence fan with breakthrough technology and innovation.
2. Beautifully finished “Dual Color and Dual Material Fan” with four color combinations and LEDs.
3. The world’s first dual-layered fan blades - combination of plastic and rubber fan blades to absorb “Wind” noise.
4. “Golf Ball” surface design on the back rubber side of the fan blades to minimize the air turbulence.
5. Optimized fan blade angle design for a perfect balance of airflow and noise.
6. Noise and shock reduction fan frame incorporating four Silencer Blocks and anti-vibration rubber pads on each mounting holes.
7. Fluid Dynamic Bearing (FDB) delivers longer life span, higher precision rotation and anti-shock function.
8. Low starting voltage of 3V.
9. Four Anti-vibration screws are included for easier installation.
10. Power cables are "black" sleeved with both 3pin and Molex 4pin connectors.
11. Low speed 7V Voltage Reduction Cable included for ultra-low speed with unrecognizable noise.
- Link/URL naar website van de fabrikant + pagina van het product
http://www.aerocool.com.tw/fan/ds/1146.html#
- Link/URL naar Reviews van het product
http://www.kitguru.net/components/c...ds-dead-silence-fan-120mm-and-140mm-review/5/
- Adviesprijs en eventueel een link naar het productpagina bij andere shops
http://www.sicomputers.nl/aerocool-ds-64130.html
- Foto's van het product
Zou je deze kunnen krijgen freddy? Vindt ze bijna nergens en sommige shops willen niet verzenden naar belgië
- Naam fabrikant
Aerocool
