EK-Vardar EVO 120ER RGB fan
[FONT=&quot][h=1]EK is finally releasing new Vardar fans with vibrant RGB lighting features![/h]May 16, 2018 | Fans
[/FONT]
[FONT=&quot]EK Water Blocks, the Slovenia-based premium computer liquid cooling gear manufacturer is releasing a new 120mm RGB version of its renowned EK-Vardar fan. Developed in-house and first introduced in 2014, the EK-Vardar fan is now also available as EK-Vardar EVO 120ER RGB. Beside the RGB lighting effect, the new fan also packs the Extended Range (ER) of PWM operation feature and the special Start-Stop function which brings a true 0dB experience for the absolute silent fan operation. The electronics of the new EVO 120ER RGB fan has been specially tweaked so that the fan stops spinning if the PWM signal falls below a certain duty cycle value. Not only will you be able to enjoy a totally silent PC, but this feature is also very useful for preventing radiator dust buildup in idling PCs and prolongs the lifecycle of the fan itself.[/FONT]
[FONT=&quot][/FONT]
[h=3]EK-Vardar EVO 120ER RGB[/h][FONT=&quot]The EK-Vardar RGB is a high-static pressure computer cooling fan, designed and built primarily for highest-performance computer liquid cooling systems. The Vardar family of cooling fans carries the notorious name of a type of the cold northwesterly wind blowing from the mountains down to the valleys of Macedonia. It is a type of ravine wind, enhanced by a channeling effect while blowing down through the Moravia-Vardar gap, bringing cold conditions from the north to the Thessaloniki area of Greece. Most frequent during winter, it is blowing in the rear of a depression when atmospheric pressure over eastern Europe is higher than over the Aegean Sea.[/FONT]
[FONT=&quot][/FONT]
[FONT=&quot]The perfectly balanced milky colored 7 fan blade design is optimized for light dispersion and high-pressure operation while maintaining the low noise profile throughout the whole operation range of the fan. Under the motor hub, there are total 9 LEDs making this the brightest RGB fan on the market, ensuring perfect light diffusion at broad daylight as well.[/FONT][FONT=&quot]One of the key features of the EK-Vardar RGB fans is its simplicity as it uses standard 4-pin 12V RGB connectivity. Meaning it can be used with any standard 4-pin 12V RGB controller or any of popular RGB sync technologies from all major motherboard manufacturers. The arrow marking on the 4-pin LED connector is to be aligned with the +12V marking on the RGB header.[/FONT]
[FONT=&quot][/FONT]
[h=3]Double-Ball Bearing for enhanced reliability and Start-Stop Function for Complete Silence![/h][FONT=&quot]The Start-Stop function featured with the EK-Vardar EVO 120ER RGB models will ensure the user a true 0dB noise environment. When fan curve is set with the minimum threshold point below 25-30% PWM duty cycle (depending on motherboard model), the motor and the electronics will turn off and the fan will simply stop spinning. EK-Vardar EVO 120ER RGB restarts operation automatically as fan control ramps up its operational duty cycle past threshold start-stop point. EK-Vardar EVO 120ER RGB models also feature Double-Ball bearing which has superior durability compared to Hydro-Dynamic bearing. Double-Ball bearing fans can tolerate higher temperatures and can be mounted in any axial orientation without concern for bearing lifespan degradation.[/FONT]
[FONT=&quot][/FONT]
[FONT=&quot]Other key characteristics of the EK-Vardar EVO 120ER RGB fan are:[/FONT]
  • High-static pressure / low noise profile – unlike other general-purpose computer cooling fans, the EK-Vardar EVO 120ER RGB fan is built specifically for computer liquid cooling systems, namely radiator cooling. The Vardar’s design and construction are also very suitable for high-performance air coolers or as case fans for restrictive cases with dust filters.
  • High-quality motor and bearing assembly – New electrical design, actively cooled motor windings and the Double-Ball bearing with 50.000 hours of lifespan (MTBF) ensures uninterrupted operation for years to come. Precise Pulse Width Modulation (PWM) for fan speed adjustment allows performance on demand.
  • Sealed-edge fan casing – The classic, yet effective square shape of the fan casing provides optimal performance in either pull- (suction) or push (pressure) regime without hydraulic losses thus ensuring the optimal cooling capacity of your liquid cooling radiators. The classic shape of the fan frame also allows easy cable routing while grouping more fans on one radiator.
  • Timeless design – the EK-Vardar EVO 120ER RGB fan with its simple square frame fits into any liquid cooling computer without drawing too much attention to itself.
  • Standard RGB connection – The Vardar RGB does not require any fancy and expensive additional RGB controller for you to enjoy vibrant lighting effects. A simple 4-pin 12V RGB connection for standard RGB controllers or any popular RGB sync technology from major motherboard manufacturers.
[h=3]In HighFlow shop:[/h]https://www.highflow.nl/aircooling/fans/ventilatoren/120mm/ek-vardar-evo-120er-rgb-500-2200-rpm.html
volcom EK-vardar series HighFlow Product Suggesties en Nieuws 13
M Stoffilter set O11 Dynamic EVO HighFlow Webshop 2
88Gamer88 EK-Supremacy EVO aanpassen voor 2066 - 7820x Waterkoeling 2
Enola kryoM.2 evo PCIe 3.0 HighFlow Webshop 8
R M.2 Evo 960 250gb Problemen & Oplossingen 6
S Ek Supremacy Evo AM4 mounting HighFlow Product Suggesties en Nieuws 1
C EK-Supremacy EVO rubber(gasket) vuil Waterkoeling 2
bundymania SSD Vergleich: OCZ Vector 150 480GB, Samsung EVO 840 1TB und Kingston HyperX 3k 120GB HighFlow Product Reviews 0
Freddy Nieuwe EKWB Supremacy EVO CPU waterblokken! HighFlow Product Suggesties en Nieuws 1
Sw333t Samsung 840 EVO 250GB HighFlow Product Suggesties en Nieuws 2
K Samsung 840 Evo's Hardware & Software 1
1 19johnny73-Johan-Recom evo power station Introductie: Stel jezelf en jouw PC voor 6
S Nanoxia X EVO 120 mm IFC - 1600 RPM HighFlow Product Suggesties en Nieuws 5
Sanders [TRA] 24Gb GeIL Evo One RAM (6 Dimms, 7-7-7-24) Verkocht 2
Rooneys Plofbox Evo Gallery & Build Logs 22
W [CANCELLED] Asus p8p67 EVO rev.3.0 Verkocht 7
R Help! Scythe Mugen past niet op Asus P8P67-EVO? Hardware & Software 15
O MC-CASE-EVO-W MagiCool EQ Liquid Cooling Case Window vragen Advies Waterkoeling Setup 7
K Hulp met overclocken Phenom XII 955 (RB-C3) // Asus M4A79XTD EVO Overclocking 3
T Dragon evo 2.2 in nieuw jasje Overige Koeling 5
V GeiL EVO Cyclone Memory Cooling System - 50mm fan HighFlow Product Suggesties en Nieuws 12
