EK-FB ASUS M6I - Nickel
WiSK
Product naam
Link
Foto
Omschrijving
EK-FB ASUS M6I water block is a complete all-in-one (CPU and motherboard) liquid cooling solution for Intel LGA-1150 socket Haswell CPU and ASUS Maximus VI Impact and Maximus VII Impact motherboards.
This water block uses award winning EK-Supremacy cooling engine to ensure best possible CPU cooling. The water blocks directly cools Intel LGA-1150 socket type CPU, Intel Z87/Z97 Express southbridge (PCH) and power regulation (VRM / MOSFETs) module as water flows directly over all critical areas. It is a very high flow water block that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality acrylic glass material. The sealing is performed by quality rubber gaskets. Plexi top variants feature two slots for easy installation of 3mm LED diodes.
Water block is mounted with enclosed M2.5x4-, M3x6- and M4x10 DIN7985 screws and PVC washers and utilizes the factory provided MOSFET backplate. The nickel plated brass screw-in standoffs are pre-installed and allow for easy installation.
EK also encloses EK-LGA 115x TRUE Backplate to ensure even contact with the CPU as well as to prevent motherboard warping.
Enclosed thermal pad is used on voltage regulator modules to improve cooling performance of the waterblock. On the CPU and southbridge (PCH) chip please use the enclosed electrically non-conductive thermal grease EK-TIM Ectotherm.
Enclosed:
- water block
- mounting mechanism
- EK-LGA 115x TRUE Backplate
- thermal grease EK-TIM Ectotherm (1g)
- thermal pads
Fittings are not enclosed! Two fittings are needed for proper operation.
Made in Slovenia - Europe!
PLEASE NOTE:
- Fittings are not included! Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
Etc
Volgens CoolingConfigurator past dit waterblock ook op de M7I. Vandaar omschrijving aangepast.
Bl4ckj4ck666 Asus rog strix x570-e gaming monoblock Handleidingen en Installatie Tips 6
Hightower Asus aio 360 HighFlow Product Suggesties en Nieuws 10
V asus aio cooler HighFlow Product Suggesties en Nieuws 3
M Asus M.2 standoff en screw HighFlow Product Suggesties en Nieuws 3
T Asus Zenith treadripper 1950X waterkoeling Gallery & Build Logs 7
A Asus Rampage II Extreme Waterkoeling. Waterkoeling 3
Hightower cablemods ledstrip asus aura ready HighFlow Product Suggesties en Nieuws 2
Freddy EK-FB ASUS R5-E10 Monoblock RGB Edition *pre-order* HighFlow Product Suggesties en Nieuws 0
Bas9466 Core xg asus hero 8 Gallery & Build Logs 4
D Bitspower ASUS MAXIMUS VII IMPACT HighFlow Webshop 1
Hightower Bitspower BP-WBAIX79R4ENPAC-CL ASUS Rampage 4 x79 HighFlow Product Suggesties en Nieuws 2
C internet snelheid op asus rampage2 extreme Problemen & Oplossingen 12
B Sli verbinding asus maximus ranger vii Waterkoeling 4
Tath Bitspower new Full cover block "Black and Clear" for Asus X99 Deluxe HighFlow Product Suggesties en Nieuws 1
