Bitspower Full Cover waterblocks for ASRock X99 OC Formula\X99 Professional
Tath
Well-known member
Bitspower nieuwe waterblocken voor de ASRock OC Formula en de X99 Professional.
Nickel Plated Full-Covered-Block (Black) en Nickel Plated Full-Covered-Block (Clear)
BP-WBTHORASRIX99FCBNPAC-BK Bitspower THOR ASRIX99 Nickel Plated Full-Covered-Block (Black)
BP-WBTHORASRIX99FCBNPAC-CL Bitspower THOR ASRIX99 Nickel Plated Full-Covered-Block (Clear)
Features:
1. Design For ASRock X99 OC Formula.
2. Included CPU/ChipSet and MOS Blocks.
3. Full-Covered-Block Design.
4. Block TOP Cover Made Of Hi-Quality Acrylic.
5. Block Base Made Of Hi-Quality Copper.
6. Block Base High Durability Nickel Finished In Shining Silver.
7. Polished Stainless Panel In Matt Black.
8. RoHS Compliant.
Dimension ( LxWxH ) : 280.3x204x49MM
Thread : G1/4" x 2
Included :
1. THOR ASRIX99 Full-Covered Armor (Clear/Black) x 1 PCS.
2. BP-MBWP-C90 x 6 PCS.
3. THOR ASRIX99 Nickel Plated (Clear) x 1 Set.
4. CPU Block Summit EF (Intel) (Acrylic Top Version) x1 Set.
5. Backup O-Ring x 1Set.
6. Thermal PAD Included.
7. Mounting Screws/Accessories.
Compatibility :
1. ASRock X99 OC Formula
2. ASRock X99 Professional
Tath Bitspower new Full cover block "Black and Clear" for Asus X99 Deluxe HighFlow Product Suggesties en Nieuws 1
Tath Bitspower Nickel Plated Full-Covered-Block Black and Clear for Gigabyte GA-X99-Gaming HighFlow Product Suggesties en Nieuws 0
P [Gezocht] Bitspower Water Tank Z-Multi 250 - Full Clear Acrylic Version BP Gevonden 0
