Xelation
Off-topic Extraordinaire
Asus to launch mATX Republic of Gamers Gene mobos
Asus Rampage II Gene - mATX Core i7 with Extreme OC potential.
We have learned that Asus will launch the "Gene" series - the company's latest addition to its Republic of Gamer (RoG) family of motherboards - in a few weeks time.
Unlike all current Republic of Gamer motherboards, the Gene series will use the micro ATX form factor and fit below Formula and Extreme, which currently signify DDR2 and DDR3 respectively. We have also heard murmurs that these labels are likely to change in the future, though.
First to emerge is the Rampage II Gene (pictured below) which will be predominantly designed for LAN gamers and extreme overclockers living in particularly small apartments. This Core i7 motherboard will directly target the new breed of mini-boards that have generated considerable interest from the likes of other manufacturers, such as DFI's JR series.
It will feature both SLI and CrossFire support, as well as two PCI-Express 2.0 x16 slots, one x4 slot and one PCI 2.2 slot. It will still feature six DIMMs, software driven X-Fi sound from ADI and also includes current RoG features like TweakIT; this will now be configurable from the keyboard instead of just from directly on the motherboard - making it far easier to access OC settings on the fly.
The general RoG features in the current Rampage II Extreme are closely mirrored on the Gene series, although we have had hints that there are some changes in design.
Sadly, for those thinking smaller equals cheaper, you'll have to think again. The Asus Republic of Gamers series is a premium product and it will certainly be over $200 in the US when it hits retail. However, for a Core i7 extreme overclocking board, some might not think that's an issue.
Asus werkt aan micro-atx-bord in Republic of Gamers-serie
Asus komt in zijn Republic of Gamers-lijn binnenkort met een moederbord op micro-atx-formaat uit. Het eerste model uit de nieuwe Gene-serie, dat voor Core i7-processors is bedoeld, beschikt over een verbeterde TweakIT-tool.
asus rampage ii geneHet micro-atx-bord, dat is gebaseerd op Intels X58-chipset en Rampage II Gene moet gaan heten, zou vanwege de overklokpotentie vooral interessant zijn voor gamers en fanatieke overklokkers, zo meldt Bit-tech. Op het bord zijn twee pci-e 2.0 x16-slots te vinden, die zowel SLI- als CrossFire-opstellingen mogelijk maken. Daarnaast is er een pci-e x4- en een pci 2.2-slot beschikbaar. In totaal zijn zes geheugensleuven aanwezig, waarin maximaal 24GB aan ddr3-repen gestoken kan worden. Voor lan-communicatie heeft Asus het moederbord met twee gigabit-ethernetpoorten uitgerust.
De ICH10R-southbridge biedt, naast een klassieke pata-poort, zes sata2-aansluitingen met raid-ondersteuning, terwijl het geluid wordt verzorgd door een onboard-geluidschip van naam SupremeFX X-Fi, die vrijwel alle extra features van Creatives X-Fi-platform zou ondersteunen. Verder heeft het bord vijf fanheaders en biedt het rondom de cpu-socket ook de benodigde bevestigingspunten voor oudere LGA775-heatsinks.
Asus heeft ook gesleuteld aan zijn TweakIT-overkloktool. In plaats van het tweaken op oudere Rampage Extreme-borden met behulp van een op de pcb bevestigde mini-joystick, kunnen de overklokinstellingen op de Rampage II Gene via een aangesloten toetsenbord worden aangepast. Naar verwachting zal het bord rond 23 februari op de Europese markt komen; de prijs zal waarschijnlijk minimaal 200 dollar bedragen.
