Hoi Freddy,
Kunnen de beide Akasa 140mm PWM
fans ook in de winkel?
Naam product
Akasa 140mm Fan APACHE Black
Code
AK-FN062
Omschrijving
Super silent 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. It’s powerful and quiet!
• Super silent APACHE BLACK 14cm fan
• S-FLOW fan blade design delivers 30% higher airflow
• Super silent with PWM speed control
• Hydro Dynamic Bearing extends fan life
Eigenschappen
Dimension |140 X 140 X 25mm
Fan speed |600 -1300 RPM
Max airflow |89.55 CFM
Max static air pressure |2.76 mm H2O
Noise level |12.5 -22.19 dB(A)
Voltage rating |12V DC
Bearing |HDB (Hydro Dynamic Bearing)
Fan life expectancy |50,000 hours
Link
http://www.akasa.com.tw/update.php?...ype=Fans&type_sub=PWM Control&model=AK-FN062#
Foto
Naam product
Akasa 140mm Fan Viper Yellow
Code
AK-FN063
Omschrijving
High performance 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. Killer Viper yellow colour makes this fan distinctive and unique.
• High performance 14cm fan in killer VIPER yellow colour
• Super silent with PWM auto speed control
• Hydro Dynamic Bearing extends fan life up to 50,000 hours
Eigenschappen
Fan speed |600 -1600 RPM
Max airflow |110.61 CFM
Max static air pressure |3.12 mm H2O
Noise level |12.5 - 26.01 dB(A)
Link
http://www.akasa.com.tw/update.php?...ype=Fans&type_sub=PWM Control&model=AK-FN063#
Foto
