updated the build log...the sidewindow designs are finally online!
--// 2009-05-11 //--
New Stuff and some tools have arrived, amongst others the package from
highflow. Well there's a jigsaw (
what would I possibly want with that?!), a couple of M4 threaded bars and other stuff. Also a Plexiglass-panel by
A.C. Ryan. Metallized.
As I was told, they are going out of production and won't be obtainable any more.
After work I went to some hardware and art supply stores, where I bought Tempera, for a little experiment of mine. It is too early to say, however, how it is going to evolve. But I will give you the solution in a couple of days...
--// 2009-05-13 //--
Two things today, regarding my project.
white water - first, the experiment I was talking about earlier, where I tried to find
a way to produce white water, well, it failed. There's no recent pic, but here's the test rig from the day before yesterday. You take: distilled water already premixed with
ACfluid ; the Tempera color in white; whisk everything up and the result will be something like that...
After a period of approximately 48 hours, the result isn't really satisfying. The anticorrosive
ACfluid is getting to the Tempera rather aggressively, so that water and color pigments are being separated quite clearly. Other than on the pictures, the mix takes after something like oil on water, if you know what I mean.
Conclusion: The first shot went badly wrong.
sidewindow design
Apart from all that, I have been working on those sketches and drawings yesterday, and here are the first results as to the design of the case windows. This is the left, the motherboard/mainside:
the very first is a classic and the little variant alludes to the case's manufacturer: YY-0420. Besides, if you all read your
Douglas Adams, you'll know, that 42, is the answer to everything.
Maybe I should also point out, that the first big window design won't come without a proper engraving...
Following are the models for the right side window - versions 3-5 accordingly, and their alternations A+B:
RV1 - my first drawing: simple, elegant, functional.
RV2 - same as source (see above).
RV3A, RV3B
RV4A, RV4B
RV5A, RV5B
RV4C - taken to extremes.
As you can see I have been toying around with the Y, this also being an allusion to
Yeong-Yang. white obvoiusly, marks the cut-out space, whereas black is metallic. Apart from RV1 I favour RV3B. What do you say?
