Monsoon Silver Bullet
Hoi hoi! Are we there yet? :073:
nee nee nee tuurlijk zat ik niet de hele dag op F5 te drukken tot dat ik In stock:
zag
Ze zijn binnen gekomen!
We zijn druk bezig met verwerken, sorteren, backorders uitdraaien etc.
Maandag worden alle backorders met Monsoon producten verzonden! :)
Code MON-LPL-MB
Monsoon Premium G 1 / 4 LED Plug - Matte Black Products Model: MON-LPL-MB [MON-LPL-MB]
Bekijk bijlage 7284
Designed for Monsoon MMRS reservoirs and Monsoon Light Port Rotary Fittings, or any G 1 / 4 port you want to add light to.
Features:
•Package includes two LED's -- an 8 degree narrow focus perfect for our Monsoon Light Port Rotaries, and a 90 degree wide angle suitable for reservoirs.
•Machined brass plug body and cap with a polished optical grade acrylic lens.
•Threaded brass locking cap holds the LED securely in place and features knurling for easy tool free installation. Machined brass plug features a radial slot allowing the use of a coin for installation.
•Rubber LED locking grommet so you don't have to remove the MOLEX plug to install or replace an LED. You can also install or replace an LED without removing the plug from your reservoir.
•LED cables are sleeved in high quality triple strand/triple weave sleeving.
•Available in all 10 Monsoon color finishes for color matching with our full line of compression and rotary fittings.
•Designed to put light where you want it without light leakage from the back of the plug.
•Ships with high quality UV color matched 2.4 mm thick silicone O-rings.
Hoi Freddy! Graag deze zwarte ook in de shop :)
Graag ook in wit MON-LPL-WH
Features:
Hoi Freddy
Graag deze ook in de shop
Naam product
Monsoon 90° Rotary Angle Fitting - 5/8" - White
Link
MON-RO-90-58-WH
Foto
Tekst
Designed to beautifully compliment the full line of Monsoon Free Center Compression Fittings. Rotary bodies for each tube size are matched to the compression ring outside diameter for a clean modern aesthetic. Brass accent color disks and fittings are sold separately allowing you to mix and match main body and accent colors. This also allows you to change fitting and accent disk colors on future builds without replacing the rotary bodies.
Features:
•Available in 45 and 90 degrees.
•Available in standard and patent pending Light Port versions.
•Color accent disks available in all 10 Monsoon color finishes allowing users to mix and match.
•Rotary body O.D. is matched to each tube size compression ring O.D. for a beautifully modern and clean aesthetic.
•Industry standard G 1 / 4 threads on both ends fit any compliant port or fitting.
•Machined from high quality solid brass castings.
•Includes high quality 2.4 mm thick silicone O-rings.
Naam product
Monsoon Standard Rotary Color Accent Disks - Blue
Link
MON-DISK-BL
Foto
S Monsoon G1/4 LED plug Oranje HighFlow Product Suggesties en Nieuws 2
S Monsoon EV2 Rigid tubing fittings HighFlow Product Suggesties en Nieuws 1
D Monsoon bending kit HighFlow Product Suggesties en Nieuws 3
JanPieter Monsoon HighFlow Product Suggesties en Nieuws 4
A monsoon waterkoeling Advies Waterkoeling Setup 5
S EK-Supremacy Backplate en monsoon fittings en co HighFlow Product Suggesties en Nieuws 4
Slader 13MM (1/2 ID - 3/4 OD) Monsoon Schroeffitting white HighFlow Product Suggesties en Nieuws 2
Thierry Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) HighFlow Product Suggesties en Nieuws 13
C info voor monsoon angled 90° en 45° fittings Waterkoeling 1
Adam Vandervorst Monsoon Schroeffitting Waterkoeling 5
T EK-Muiltioption Reservoir en monsoon fittings. Waterkoeling 3
Thierry Monsoon Free Center Compression Fittings HighFlow Product Suggesties en Nieuws 19
Jason EK-Quantum Vector FE RTX 3080 D-RGB Special Edition - Silver HighFlow Product Suggesties en Nieuws 0
Jason EK-Quantum Vector FE RTX 3090 D-RGB - Silver and Black Special Edition HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX – Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black & Silver HighFlow Product Suggesties en Nieuws 0
Jason EK-Quantum Vector FE RTX 3080 D-RGB The Special Edition - Black or Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX - Black or Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black/Silver HighFlow Product Suggesties en Nieuws 0
Jason BarrowCH Rhopilema Series V2 Limited Edition Composite Channel Test Bench Case - Silver HighFlow Product Suggesties en Nieuws 0
HighFlow EK-Quantum InWin 909EK - Silver Limited Edition HighFlow Product Suggesties en Nieuws 2
R Mayhems Aurora 2 Silver voor lang gebruik? (1 jaar) Waterkoeling 1
AQuAKiNG 750D X99 Black/White/Silver theme Gallery & Build Logs 46
Traxtorm Lian Li CD/DVD Bezel Silver Verkocht 0
gerjanlubbers Bitfenix project silver. Gallery & Build Logs 1
l3p [TKA-Alu Panels] A.C. Ryan AluPanel™ 500x500mm Brushed Anodized (1/2mm Silver/Black) Verkocht 2
Sw333t Silverstone SST-FP58S 5.25 Slim ODD and 2.5 HDD Bay Silver HighFlow Product Suggesties en Nieuws 2
Tath Test thermal compound (Artic Silver 5 e.d.) Handleidingen en Installatie Tips 3
B Alphacool NexXxoS Pro II Radiator Rev. 2 & Phobya Balancer 450 silver nickel HighFlow Product Suggesties en Nieuws 3
B Bitspower Silver shining vs Alphacool Chrome kleur Waterkoeling 2
D [GEVONDEN] 2x 90 graden G1/4 x 3/8 x 1/2 silver shiny Gevonden 3
P Stripes 480mm Satin SILVER? Radiator Grill HighFlow Product Suggesties en Nieuws 30
S Bitspower silver shiny 45° compression fitting 1/2 ID 3/4 OD HighFlow Product Suggesties en Nieuws 3
E lappen & artic silver 5 of indigo Xtreme? Overige Koeling 8
L Window panel gezocht voor Lian Li PC-8FIA (silver) Cases en Modding 3
alain-s [IN-ACTIVE] Aqua-Computer RadGrillz Stripes 3x120mm Silver Verkocht 1
l3p [VERKOCHT] Diverse Bitspower Silver Shiny Verkocht 8
soppy Aerocool Silver Lightning 140mm Silent White LED Fan HighFlow Product Suggesties en Nieuws 7
Sw333t [VERKOCHT] 8x BP Silver Shiny + 2x Feser Verkocht 7
