Monsoon Silver Bullet
WiSK
Monsoon Silver Bullet, Light Ports en Rotaries
Naam product
Silver Bullet
Naam fabrikant
Monsoon
Link
Monsoon Cooling
Monsoon Silver Bullet Antimicrobial G1/4 Plug Products Model: MON-PLUG-AG-BLK [MON-PLUG-AG-BLK] : HighFlow.nl
Foto
Monsoon has taken the proven microbe killing power of silver and plated it onto a patent pending reservoir plug that is better looking, easier to install, stays where you put it, and is painless to replace, usually without requiring you to break down your loop.
WiSK
Ik heb direct gevraagd aan BoxGods, eigenaar van Monsoon. Volgens hem heeft de europese distributor rotary fittings enz besteld maar geen silver bullets.
No they haven't ordered Silver bullets yet. You might mention it to them via email as customer requests/feedback always helps, and I can add them to their rotary order when it ships.
Ik wil wel iemand mailen, maar denk kan beter hier gewoon melden en aan jou overlaten :)
WiSK
WiSK
Volgens mij kan je het beste kijken op de PPCs shop en de productcode en weblink doorgeven aan Freddy.
Monsoon G1/4 Plugs
Bijvoorbeeld,
Code MON-LPL-MB
Monsoon Premium G 1 / 4 LED Plug - Matte Black Products Model: MON-LPL-MB [MON-LPL-MB]
Designed for Monsoon MMRS reservoirs and Monsoon Light Port Rotary Fittings, or any G 1 / 4 port you want to add light to.
Features:
•Package includes two LED's -- an 8 degree narrow focus perfect for our Monsoon Light Port Rotaries, and a 90 degree wide angle suitable for reservoirs.
•Machined brass plug body and cap with a polished optical grade acrylic lens.
•Threaded brass locking cap holds the LED securely in place and features knurling for easy tool free installation. Machined brass plug features a radial slot allowing the use of a coin for installation.
•Rubber LED locking grommet so you don't have to remove the MOLEX plug to install or replace an LED. You can also install or replace an LED without removing the plug from your reservoir.
•LED cables are sleeved in high quality triple strand/triple weave sleeving.
•Available in all 10 Monsoon color finishes for color matching with our full line of compression and rotary fittings.
•Designed to put light where you want it without light leakage from the back of the plug.
•Ships with high quality UV color matched 2.4 mm thick silicone O-rings.
WiSK
Hoi Freddy, kan deze erbij. Ik wil toch wat 45 graden fittings van Monsoon ipv die Feser rotaries. Alvast dank! :)
Code MON-DISK-WH
Monsoon Standard Rotary Color Accent Disks - White Products Model: MON-DISK-WH [MON-DISK-WH] : Performance-PCs.com, ... sleeve it and they will come
Product Details:
Available in all 10 Monsoon color finishes, these color Accent Disks allow users to customize their Monsoon Standard Rotary Angle Fittings.
Features:
  • Stamped from 1mm brass sheet.
  • Available in all 10 Monsoon color finishes.
  • Easily installed in seconds with the included industrial grade double backed adhesive pads.
  • Mix and match with fitting and rotary body colors to perfectly compliment your build
  • Users can etch or paint custom artwork for a truly custom look.
S Monsoon G1/4 LED plug Oranje HighFlow Product Suggesties en Nieuws 2
S Monsoon EV2 Rigid tubing fittings HighFlow Product Suggesties en Nieuws 1
D Monsoon bending kit HighFlow Product Suggesties en Nieuws 3
JanPieter Monsoon HighFlow Product Suggesties en Nieuws 4
A monsoon waterkoeling Advies Waterkoeling Setup 5
S EK-Supremacy Backplate en monsoon fittings en co HighFlow Product Suggesties en Nieuws 4
Slader 13MM (1/2 ID - 3/4 OD) Monsoon Schroeffitting white HighFlow Product Suggesties en Nieuws 2
Thierry Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) HighFlow Product Suggesties en Nieuws 13
C info voor monsoon angled 90° en 45° fittings Waterkoeling 1
Adam Vandervorst Monsoon Schroeffitting Waterkoeling 5
T EK-Muiltioption Reservoir en monsoon fittings. Waterkoeling 3
Thierry Monsoon Free Center Compression Fittings HighFlow Product Suggesties en Nieuws 19
Jason EK-Quantum Vector FE RTX 3080 D-RGB Special Edition - Silver HighFlow Product Suggesties en Nieuws 0
Jason EK-Quantum Vector FE RTX 3090 D-RGB - Silver and Black Special Edition HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX – Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black & Silver HighFlow Product Suggesties en Nieuws 0
Jason EK-Quantum Vector FE RTX 3080 D-RGB The Special Edition - Black or Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Wraith Mini ITX/DTX - Black or Silver HighFlow Product Suggesties en Nieuws 0
Jason Singularity Computers Spectre 3.0 - Black/Silver HighFlow Product Suggesties en Nieuws 0
Jason BarrowCH Rhopilema Series V2 Limited Edition Composite Channel Test Bench Case - Silver HighFlow Product Suggesties en Nieuws 0
HighFlow EK-Quantum InWin 909EK - Silver Limited Edition HighFlow Product Suggesties en Nieuws 2
R Mayhems Aurora 2 Silver voor lang gebruik? (1 jaar) Waterkoeling 1
AQuAKiNG 750D X99 Black/White/Silver theme Gallery & Build Logs 46
Traxtorm Lian Li CD/DVD Bezel Silver Verkocht 0
gerjanlubbers Bitfenix project silver. Gallery & Build Logs 1
l3p [TKA-Alu Panels] A.C. Ryan AluPanel™ 500x500mm Brushed Anodized (1/2mm Silver/Black) Verkocht 2
S Silverstone SST-FP58S 5.25 Slim ODD and 2.5 HDD Bay Silver HighFlow Product Suggesties en Nieuws 2
Tath Test thermal compound (Artic Silver 5 e.d.) Handleidingen en Installatie Tips 3
B Alphacool NexXxoS Pro II Radiator Rev. 2 & Phobya Balancer 450 silver nickel HighFlow Product Suggesties en Nieuws 3
B Bitspower Silver shining vs Alphacool Chrome kleur Waterkoeling 2
D [GEVONDEN] 2x 90 graden G1/4 x 3/8 x 1/2 silver shiny Gevonden 3
P Stripes 480mm Satin SILVER? Radiator Grill HighFlow Product Suggesties en Nieuws 30
S Bitspower silver shiny 45° compression fitting 1/2 ID 3/4 OD HighFlow Product Suggesties en Nieuws 3
E lappen & artic silver 5 of indigo Xtreme? Overige Koeling 8
L Window panel gezocht voor Lian Li PC-8FIA (silver) Cases en Modding 3
alain-s [IN-ACTIVE] Aqua-Computer RadGrillz Stripes 3x120mm Silver Verkocht 1
l3p [VERKOCHT] Diverse Bitspower Silver Shiny Verkocht 8
soppy Aerocool Silver Lightning 140mm Silent White LED Fan HighFlow Product Suggesties en Nieuws 7
S [VERKOCHT] 8x BP Silver Shiny + 2x Feser Verkocht 7
the_cyberspace Bitspower G1/4" Silver Shining IG1/4" Extenders HighFlow Product Suggesties en Nieuws 2
E [Gezocht] Bitspower G1/4 Silver Shiny Rotary 90 Degree ID 1/4 Adapter Gevonden 0
