Bitspower waterblok voor de EVGA GeForce GTX 970 SuperClocked ACX Design VGA Card
Tath
Well-known member
Nieuwe Bitspower waterblok Acrylic Top With Stainless Panel (Clear) voor de EVGA GeForce GTX 970 SuperClocked ACX Design VGA Card.
BP-WBVGNGTX970ESACXNPAC Bitspower VG-NGTX970ESACX Acrylic Top With Stainless Panel (Clear)
Features:
1. Design For EVGA GeForce GTX 970 SuperClocked ACX Design VGA Card.
2. Direct-Flow Design On Inlet/Outlet.
3. TOP Cover Made Of Acrylic And Stainless.
4. Block Base Made Of C1100.
5. Bottom High Durability Nickel Finished In Shining Silver.
6. Polished Stainless Panel In Shining Silver Fixed.
7. Bitspower Back-Plane Included.
8. RoHS Compliant.
Dimension ( LxWxH ) :219.5x126x18.5 MM (Out-Line)
Thread : G1/4" x 2
LED Hole : 5MM x 3
Included :
1. Fujipoly Thermal PAD Included.
(Please Reference The Installation Guide.)
2. Silver Shining Stop Fitting x 2PCS.
3. Backup O-Ring For VG-NGTX970ESACX x 1Set.
4. Bitspower Backplane x 1PCS
5. Mounting Screws/Accessories.
***All Specification Will Be Changed Without Further Notice***
the_cyberspace Bitspower VGA waterblok HighFlow Product Suggesties en Nieuws 16
