Bitspower THOR ASRIX99 Nickel Plated (Clear) for X99 OC Formula and X99 Professional
Tath
Well-known member
Nieuwe blokken voor de ASRock X99 OC Formula and X99 Professional
BP-WBTHORASRIX99NPAC-CL Bitspower THOR ASRIX99 Nickel Plated (Clear)
Features:
1. Design For ASRock X99 OC Formula.
2. Included ChipSet and MOS Blocks.
3. Real Full Water-Cooled Solution.
4. Block TOP Cover Made Of Hi-Quality Acrylic.
5. Block Base Made Of Hi-Quality Copper.
6. Block Base High Durability Nickel Finished In Shining Silver.
7. Polished Stainless Panel In Matt Black.
8. RoHS Compliant.
Dimension N+S ( LxWxH ) : 204x160.2x26MM
Dimension MOS ( LxWxH ) : 104.7x30.5x26MM
Thread : G1/4" x 2
Included :
1. Backup O-Ring x 1Set.
2. Thermal PAD Included.
3. Mounting Screws/Accessories.
Compatibility :
1. ASRock X99 OC Formula
2. ASRock X99 Professional
***All Specification Will Be Changed Without Further Notice***
