Bitspower Nickel Plated Full-Covered-Block Black and Clear for MSI X99S SLI PLUS
Tath
Well-known member
Bitspower nieuwe blokken voor de MSI X99S SLI PLUS in twee uitvoeringen "Clear"en "Black".
BP-WBBRAGIMIX99FCBNPAC-BK Bitspower BRAGI MIX99 Nickel Plated Full-Covered-Block (Black)
BP-WBBRAGIMIX99FCBNPAC-CL Bitspower BRAGI MIX99 Nickel Plated Full-Covered-Block (Clear)
Features:
1. Design For MSI X99S SLI PLUS.
2. Included CPU/ChipSet and MOS Blocks.
3. Full-Covered-Block Design.
4. Block TOP Cover Made Of Hi-Quality Acrylic.
5. Block Base Made Of Hi-Quality Copper.
6. Block Base High Durability Nickel Finished In Shining Silver.
7. Polished Stainless Panel In Matt Black.
8. RoHS Compliant.
Dimension ( LxWxH ) : 285.1x152.5x49mm
Thread : G1/4" x 2
Included :
1. MIX99SP Full-Covered Armor (Clear/Black) x 1 PCS.
2. BP-MBWP-C90 x 6 PCS.
3. MIX99SP Nickel Plated (Clear) x 1 Set.
4. CPU Block Summit EF (Intel) (Acrylic Top Version) x1 Set.
5. Backup O-Ring x 1Set.
6. Thermal PAD Included.
7. Mounting Screws/Accessories.
Compatibility :
1. MSI X99S SLI PLUS
Tath "New" Bitspower Nickel Plated (Clear) voor de Gigabyte GA-X99-Gaming G1 WIFI HighFlow Product Suggesties en Nieuws 0
Tath Bitspower Nickel Plated Full-Covered-Block Black and Clear for Gigabyte GA-X99-Gaming HighFlow Product Suggesties en Nieuws 0
Tath Bitspower THOR ASRIX99 Nickel Plated (Clear) for X99 OC Formula and X99 Professional HighFlow Product Suggesties en Nieuws 0
D Bitspower AIZ97M7IITX Nickel Plated (Clear) HighFlow Product Suggesties en Nieuws 1
Zwelgje Bitspower VG-NGTX780TI Nickel Plated ICE Black Acrylic Top HighFlow Product Suggesties en Nieuws 1
P Bitspower AIZ87M6IITX Nickel Plated HighFlow Product Suggesties en Nieuws 4
Thierry Bitspower black nickel plated fittings HighFlow Product Suggesties en Nieuws 27
k.3nny [IN-ACTIVE] Bitspower Black nickel X58 classified *e(serie) Verkocht 8
Thierry Bitspower G1/4 Black nickel Five Rotary Snake-Style HighFlow Product Suggesties en Nieuws 5
