Bitspower Colored Acrylic / Rigid tubing
Nu uit voorraad leverbaar :)
12mm
Bitspower None Chamfer Crystal Link Tube OD 12MM - Length 500mm - Black - BP-NCCLT12ACBK-L500
Bitspower None Chamfer Crystal Link Tube OD 12MM - Length 500mm - Blue - BP-NCCLT12ACBL-L500
Bitspower None Chamfer Crystal Link Tube OD 12MM - Length 500mm - Red - BP-NCCLT12ACRD-L500
Bitspower None Chamfer Crystal Link Tube OD 12MM - Length 500mm - White - BP-NCCLT12ACWH-L500
16mm:
Bitspower None Chamfer Crystal Link Tube OD 16MM - Length 500mm - Black - BP-NCCLT16ACBK-L500
Bitspower None Chamfer Crystal Link Tube OD 16MM - Length 500mm - Blue - BP-NCCLT16ACIBL-L500
Bitspower None Chamfer Crystal Link Tube OD 16MM - Length 500mm - Red - BP-NCCLT16ACIRD-L500
Bitspower None Chamfer Crystal Link Tube OD 16MM - Length 500mm - White - BP-NCCLT16ACWH-L500
