Bitspower AIZ97M7IITX Nickel Plated (Clear)
djangel
hallo ik heb een vraag kan deze Block in de shop komen zo dat ik hem kan bestelen
Model Name:BP-WBAIZ97M7IITXNPAC-CL
Water-Cooling / Full Board Style M/B Water-Cooling Block / ASUS
Features :
1. Design For ASUS MAXIMUS VII IMPACT (Intel Z97).
2. Unibody Style Construction Design. (U.S.C.)
3. North + South CHIPSET ONE Piece Design With MOS Block.
4. Cover Almost All Heat Area.
5. Real Full Water-Cooled Solution.
6. Block TOP Cover Made Of Hi-Quality Acrylic.
7. Block Base Made Of Hi-Quality Copper.
8. Block Base High Durability Nickel Finished In Silver.
9. RoHS Compliant.
( LxWxH ) : 151.6x131.6x43.05MM
Thread : G1/4" x 2
Included :
1. Thermal PAD Included.
2. Backup O-Ring For AIZ97M7IITX x 1Set.
3. Mounting Screws/Accessories.
***All Specification Will Be Changed Without Further Notice***
Hi-Quality Water-Cooling Products From Taiwan
Bijlagen
    4,7 KB · Weergaven: 21
    4,4 KB · Weergaven: 21
    6,4 KB · Weergaven: 21
