120mm EXT Universal Radiator Stand - 3/16" - Black Powdercoat
SeaShark
- 120mm EXT Universal Radiator Stand - 3/16" - Black Powdercoat
- LiquidHaus
- Introducing the EXT.
The EXT V2 is an updated take on the V1 EXT universal radiator stand designed for handling any size radiator that utilizes either the 120mm or 140mm form factor.
Made from 3/16” steel in the USA, this stand is a unit in its own right, and will securely hold and balance your external radiator without issue.
With a new sliding mount system, you can flip the radiator so that the end tanks can fit at the bottom for an additional placement option.
  • Made from 3/16" thick steel and powder-coated black, this radiator stand is designed to withstand any size radiator utilizing the traditional 120mm form factor.
  • Utilizing an adjustable mount system, this re-design allows radiator end tanks to be installed at the bottom, allowing more possibilities for tube routing or overall preference.
  • Comes with two 3/16" aluminum spacers for rear fan mounting, as well as four adhesive rubber dampening pads (bottom surface must be clean for adhesive pads to stick properly!)
- https://www.liquidhaus.com/products/v2-ext-universal-radiator-stand-120mm-matte-black
- 77,48 euro
Alvast dank!
Jason Be Quiet! Light Wings 120mm & 140mm PWM High-speed - Triple Pack HighFlow Product Suggesties en Nieuws 0
Jason Noiseblocker NB-eLoop X B12-PS ARGB - 120mm - Black HighFlow Product Suggesties en Nieuws 0
Slader noiseblocker NB-ELOOP X B12-PS ARGB BLACK EDITION - 120MM HighFlow Product Suggesties en Nieuws 1
Jason Gelid Solutions Stella - 120mm ARGB Fan HighFlow Product Suggesties en Nieuws 0
iSP Alpenföhn Wingboost 2 120mm Blood Red Review (English) HighFlow Product Reviews 0
C Corsair Air Series AF120 LED Quiet Edition Wit Twin Pack, 120mm HighFlow Product Suggesties en Nieuws 2
S Template gaten 120mm voor radiator Cases en Modding 4
iSP Alpenföhn WingBoost2 120mm fans suggestie HighFlow Product Suggesties en Nieuws 10
Slader delta 120mm fan HighFlow Product Suggesties en Nieuws 2
Freddy 120mm fans (DeepCool) vanaf 2,95 euro. OP = OP HighFlow Computer Cooling Shop 1
Pharlap [VERKOCHT] 9x Coolink SWiF2-120P, 120mm, 1700rpm, Groen/Grijs Verkocht 7
Rooneys [VERKOCHT] 3x Corsair SP120 Twin Pack, 120mm Verkocht 1
volcom Aerocool DS Dead Silence Fan 120mm Red HighFlow Product Suggesties en Nieuws 8
Sw333t [VERKOCHT] 2x be quiet! Shadow Wings 120mm Mid-Speed Verkocht 2
k.3nny Gezocht: 4x rode ledfans 120mm Gevonden 0
R NZXT FZ 120mm HighFlow Product Suggesties en Nieuws 5
Hightower corsair af series 120mm led. HighFlow Product Suggesties en Nieuws 6
Hightower welke 120mm casefan? Overige Koeling 3
volcom Cooler Master Jetflo 120mm Red HighFlow Product Suggesties en Nieuws 9
T Alphacool plexi light module en nanoxia 120mm pwm HighFlow Product Suggesties en Nieuws 2
S gelid silent slim 120mm pwm HighFlow Product Suggesties en Nieuws 2
coolfris Akasa Viper, 120mm, 1900rpm, Geel HighFlow Product Suggesties en Nieuws 1
l3p [VERKOCHT] 3x Scythe 120MM Gentle Typhoon 3000RPM D1225C12B7AP-29 Verkocht 2
ChillPascal [VERKOCHT] 3x Corsair SP's & Phobya G-Changer 120mm Verkocht 9
sir serial [GEVONDEN] 120mm fans Gevonden 5
M [VERKOCHT] Bitspower reservoir en diverse 120mm fans te koop! Verkocht 2
Joren [IN-ACTIVE]120mm Radiator, EK supreme, Fittingen Verkocht 7
Joren [IN-ACTIVE] 120mm radgrill Gevonden 7
Joren [IN-ACTIVE] 120mm radiator, cheap. Gevonden 1
Legendary1985 [GEVONDEN] 120MM fan Gevonden 1
G Akasa Apache 120mm ---> 80mm HighFlow Product Suggesties en Nieuws 1
l3p [VERKOCHT] 3 x Scythe Gentle Typhoon D1225C12B4AP-14 (1450 rpm) 120mm Verkocht 1
l3p [VERKOCHT] 5 x BitFenix Spectre Pro Led Red 120mm Verkocht 4
l3p [VERKOCHT] 3 x Cooler Master V6GT 120mm Verkocht 1
T 120MM Fan Grill? HighFlow Product Suggesties en Nieuws 3
