Lian-Li PC-A77F
Colossus
[HF]
Model: PC-A77F
Case Type: Full Tower
Dimensions: (W) 220mm x (H) 572mm x (D) 590mm
Front bezel Material: Aluminum
Color: Black, Silver
Side Panel: Aluminum
Body Material: Aluminum
Net Weight: 9.2KG
5.25" drive bay (External): 12
3.5" drive bay (External)
3.5" drive bay (Internal): 9 (Use 5.25 x 6 Bays)
Expansion Slot: 8
Motherboard: E-ATX / ATX / M-ATX/ CEB
System Fan (Front): 120mm Blue LED Fan x 3 (1200RPM)
System Fan (Top): 140mm Fan x 2 (1000RPM)
System Fan (Rear): 120mm Fan x 1 (1500RPM)
I/O Ports: USB3.0 x 4 / e-SATA x1 / HD+AC97 Audio
Maximum Video Card Size: 365mm
Package Dimensions: (W) 280mm x (H) 685mm x (D) 706mm
Gross Weight: KG
LightStar Lian Li PC-A77F HighFlow Product Suggesties en Nieuws 17
