Alphacool Core 1 LT Aurora Acrylic
SeaShark
- Core 1 LT Aurora Acrylic
- Alphacool
- Product information
With the Core 1 LT, Alphacool presents the light version of the proven Core 1 CPU water cooler. Housed in a polymer casing, the Core 1 LT also uses the reliable combination of 3D jetplate and cross slot-technology. This enables it to effectively dissipate the enormous waste heat of the latest desktop processors. With its elegant design, it integrates seamlessly into any water cooling system. The new mounting system is also included and simplifies installation with Intel and AMD processors.
The best of new and old
Alphacool combines the best of both worlds with the Core 1 water cooler series. In addition to the new 3D jetplate, Alphacool returns to its roots by distributing the coolant evenly across the redesigned cooler base using proven cross-slot technology. Inside the cooler, O-rings ensure a precise water flow and thus guarantee effective cooling. The nickel-plated copper base of the cooler has been enlarged to achieve full coverage of large CPUs.
New Mounting System
The mounting system has also been revised. Compared to previous Alphacool models, it requires fewer screws. First, the pre-assembly of the backplate (Intel) is done with four spacers. After that, the thermal paste is applied to the CPU. Then, the matching mounting frame is put on the CPU cooler and fastened with four nuts on the spacers.
Core Design
The functional and elegant design is a central element of the Core series from Alphacool. Its focus is on cooling performance at a fair price. The rounded corners add the perfect touch to the overall look. The Core 1 LT is available in both non-illuminated and transparent aRGB versions.
Compatibility:
- Attention: The Eiszapfen PRO 16mm HardTube fittings cannot be used with this CPU cooler!
- https://shop.alphacool.com/en/shop/cpu-water-cooling/intel/13886-alphacool-core-1-lt-aurora-acrylic
- €79,98
dark viper zwolle Alphacool Cape Fuzion Core 10 Acetal Black HighFlow Product Suggesties en Nieuws 4
bundymania [User Review] Alphacool Cape Fuzion Core 10 & 30 - Acetal - Black Reservoir HighFlow Product Reviews 1
C [User-Review]Alphacool Cape Fuzion Core 30 Acetal Black in Cartago´s Review HighFlow Product Reviews 3
V Alphacool Eisbaer LT, pompvermogen voldoende? Waterkoeling 4
