liquid cooling system
alexia
Hi. I would like to know if someone could give me some advice about a liquid cooling system for a HIS 6970 graphic card. I am thinking about changing the original one because the noise is too high.
I have attached a print screen with some details about the graphic card.
Thank you!
Bijlagen
    37,4 KB · Weergaven: 21
Thank you!
First of al I would like to recommend you to look at CoolingConfigurator.com
This is a website from EK Wateblocks where you can find a compatible Block for your Card
I would Recommend Going with a Full cover Block if available
Than Look For A Good Pump Like A Laing DDC or D5
and not to forget A Radiator that can fit in your PC-case (or en external one if you prefer)
How bigger your radiator how better the cooling performance will be and you will be able to run the fans at lower speeds for a more quite system
I hope this helps you out a bit
Added after 28 minutes:
Almost forgot ...
You will also need a reservoir to feed the pump and make it easier to fill your loop
and some fittings (2 for each component) and Tubing to make the loop
M Mijn eerste Liquid Cooling System Waterkoeling 8
C Info componenten custom liquid cooling set Advies Waterkoeling Setup 26
Freddy EK-Predator is setting a new standard for AIO liquid cooling! HighFlow Product Suggesties en Nieuws 6
Alex EK H3O Advanced Liquid Cooling Kit HighFlow Product Suggesties en Nieuws 11
J wie kan voor mij een heel nieuw liquid cooling systeem samenstellen. Advies Waterkoeling Setup 96
O MC-CASE-EVO-W MagiCool EQ Liquid Cooling Case Window vragen Advies Waterkoeling Setup 7
Slader Danamics LMX: Liquid cooling is back HighFlow Product Suggesties en Nieuws 6
N Danamics LM10 - Metal Liquid Cooling HighFlow Product Suggesties en Nieuws 71
Fiftykilowatt Liquid North Overige Builds 2
Bl4ckj4ck666 MSI Z97 GAMING 9 ACK LIQUID COOLED DESKTOP Hardware & Software 7
S Primochill Vue Koelvloeistof / Liquid / Coolant HighFlow Product Suggesties en Nieuws 108
Freddy Liquid.cool Koelvloeistof / Coolant / Componenten HighFlow Product Suggesties en Nieuws 1
meneer peer Coollaboratory liquid Ultra 1ML HighFlow Product Suggesties en Nieuws 3
Hightower Liquid extasy waterblokken HighFlow Product Suggesties en Nieuws 41
V Liquid SLI upgrade 1400/1500,- Budget Advies Waterkoeling Setup 26
arwin74 540 Liquid Gallery & Build Logs 51
WiSK Coollaboratory Liquid Copper HighFlow Product Suggesties en Nieuws 1
C ASUS Republic of Gamers FERRARI RED Liquid Cooled PC Introductie: Stel jezelf en jouw PC voor 7
ChillPascal FrozenQ Liquid Fusion Blue Reservoir V2 Waterkoeling 2
bundymania [Bundymania Kurzreview] Liquid Extasy Universalkühler VUCI - die günstige Alternative HighFlow Product Reviews 2
Asphiax Koolance LIQ-702 Liquid Coolant Bottle, High-Performance, 700mL (UV Red) HighFlow Product Suggesties en Nieuws 2
aadje93 Coollaboratory Liquid Ultra HighFlow Product Reviews 55
D Koolance Liquid Coolant Bottle, High-Performance, 700mL (Colorless) HighFlow Product Suggesties en Nieuws 1
Besje Liquid Extasy Rampage 3 Gene fullcover block HighFlow Product Suggesties en Nieuws 5
E Levertijd FrozenQ Liquid Fusion Blauw HighFlow Computer Cooling Shop 18
M FrozenQ Liquid Evolution HighFlow Product Suggesties en Nieuws 3
Vissa [VERKOCHT] FrozenQ Liquid Fusion Red Reservoir Verkocht 1
Vissa [VERKOCHT] FrozenQ Liquid Fusion Red 250MM Verkocht 11
MrGiorgio Indigo liquid metal HighFlow Product Suggesties en Nieuws 14
F FrozenQ Liquid Fusion Reservoir barst! Waterkoeling 43
Don_Holio Don's Liquid i7 Gallery & Build Logs 7
Thierry Liquid Extasy HighFlow Product Suggesties en Nieuws 15
Robin Gigabyte x58 UD5 / xtreme Liquid blocks. HighFlow Product Suggesties en Nieuws 6
Craven liquid metalpad HighFlow Product Suggesties en Nieuws 3
Oli4v WC Log: Liquid P182 Gallery & Build Logs 188
stravinski Modified TT Kandalf Liquid cooled, Stravinski & Ralpios Cases en Modding 270
