Corsair 600TM
Well its seems i forgot to post my hardware with this build so ill do so now.
Case : Corsair 600TM
Mobo : Gigabyte GA-990FXA-UD7 (rev. 1.1)
CPU : AMD FX 4170 @4.2 (Stock)
Mem : 8 GB ( 2 x 4GB ) Corsair Vengeance DDR3-1600
GPU : XFX 7970 3GB Ghz Edition
PSU : Cooler Master GX 650W (Yes 650W)
For now this is whats in there.
