XSPC Typhoon
vincent
Gouden member
Zelf niet nodig, Mooie toevoeging voor de shop:
- Support one or two DDC pumps
- G1/4" Thread
- Dimensions: 149 x 104 x 85.5mm
- Removable faceplate
- High Quality Acrylic
- Brass screw threads
- 3x 5mm LED holes
- Individually pressure tested
Sw333t Thermochill EC6 / XSPC EC6 HighFlow Product Suggesties en Nieuws 2
4 xspc pomp Waterkoeling 4
P XSPC Spare D5 Bracket Set HighFlow Product Suggesties en Nieuws 3
Sw333t XSPC Dual 5.25" Bay Reservoir - Black - Ball Front (BR525DBW) HighFlow Product Suggesties en Nieuws 2
W Problem whit my XSPC Pomp 2 International Forum 2
M XSPC waterkoelings kit? Wacht nog even tot januari! Waterkoeling 2
