Welk nummer luister je atm? (Muziek)
<object width="600" height="400"><param name="movie" value="http://www.youtube.com/v/2AQr06ZUlR0?fs=1&hl=nl_NL&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2AQr06ZUlR0?fs=1&hl=nl_NL&hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="600" height="400"></embed></object>
en de betere van ZEDs DEAD
<object width="600" height="400"><param name="movie" value="http://www.youtube.com/v/IUGzY-ihqWc?fs=1&hl=nl_NL"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/IUGzY-ihqWc?fs=1&hl=nl_NL" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="600" height="400"></embed></object>
Precies ;)
Wèl ben ik van mening dat elke "vuurwerk" liefhebber het volgende nr. hoort te kennen ;)
(het into was de herkenning van VARA's vuurwerk)
*edit*
Het titel stuk van het album:
<object height="81" width="100%"> <param name="movie" value="http://player.soundcloud.com/player.swf?url=http%3A%2F%2Fapi.soundcloud.com%2Ftracks%2F8620531&show_comments=false&auto_play=false&color=ff7700"></param> <param name="allowscriptaccess" value="always"></param> <embed allowscriptaccess="always" height="81" src="http://player.soundcloud.com/player.swf?url=http%3A%2F%2Fapi.soundcloud.com%2Ftracks%2F8620531&show_comments=false&auto_play=false&color=ff7700" type="application/x-shockwave-flash" width="100%"></embed> </object> <span><a href="http://soundcloud.com/max-go-chris-lawr/floating-away">Floating Away (Original Mix)</a> by <a href="http://soundcloud.com/max-go-chris-lawr">Max Go & Chris Lawr</a></span>
J welk waterblock? Waterkoeling 3
W ervaring met koelblok op R9 280X Toxic? Welk koelblok past? Advies Waterkoeling Setup 2
D Welk monitor voor ps4 en pc vraag Gaming 31
melchiortheijs Welk spoelmiddel gebruiken? Waterkoeling 8
Hightower welk moederbord? Hardware & Software 3
C custom backplates voor GPU's welk materiaal ? Cases en Modding 3
Hightower welk ek fullcover block voor de evga 660ti ftw gtx Waterkoeling 2
M welk MB voor mijn fx 8350? Hardware & Software 10
R Welk blok op Club3d 6950 CoolStream 2GB Waterkoeling 4
S Welk block voor HD6970? Waterkoeling 9
E Welk shroud? Waterkoeling 2
J Welk GPU blok is beter? Waterkoeling 2
E Welk geheugen voor een Asus p8p67 moederbord Hardware & Software 5
HighSpeed^ [Downloaden] Welk programma gebruik jij? Hardware & Software 35
C Welk licht zou goed zijn? Cases en Modding 25
M HD6990, welk blok? Waterkoeling 1
F welk 1366 bord nemen Hardware & Software 11
F welk moederbord moet ik nemen Hardware & Software 6
Alex Swiftech MCR bouten, welk formaat? HighFlow Product Suggesties en Nieuws 7
w4rlock Het; Welk merk hardeschijf zijn beter topic. Algemene Discussies 19
D Welk i7 moederbord? Hardware & Software 44
Sparky Installatie Koolance Chipset blok: Welk thermal stripje moet waar?? Waterkoeling 3
M Welk WC setup het beste? Waterkoeling 1
M5rvii Welk waterblok voor NB van Gigabyte GA-P35C-DS3R Waterkoeling 1
M5rvii Welk RAM blok op 1g DDR2 800 DIMM 5-5-5 Transcend? Waterkoeling 10
Freddy Welk programma voor afspelen van Blu Ray schijven? Hardware & Software 24
Deleted_User_Z Welk block past op mijn gtx 285 1 gb Waterkoeling 19
N Welk mobo? Hardware & Software 11
fasster Welk formaat schroefdraad heeft de Black Ice GTS 240? Waterkoeling 2
B Welk CPU-blok? Waterkoeling 14
K0G3L Welk geheugen voor Maximus III Gene ? Hardware & Software 24
dopestuff welk alterego heb jij?? Algemene Discussies 39
G Welk moederbord voor mijn casemod; Ipple I5 Hardware & Software 2
P .doc documenten in server 2003 .. welk programma kan dat Problemen & Oplossingen 5
M Club3d HD4870 Welk waterblok past erop?? Waterkoeling 11
Flythe Naar welk concert/optreden ga jij binnenkort toe? Algemene Discussies 78
J welk waterblok op mn gt7900 Advies Waterkoeling Setup 6
K0G3L Welk internet abonnement ? Algemene Discussies 9
MonsterEnergy Welk moederbord? Hardware & Software 8
H Welk moederbord Overclocking 8
m.d.koning Welk CPU blok zal ik gebruiken? Waterkoeling 20
