Waterkoeling i7 965 Extreme, Rampage II Gene (cpu/mobo.)
Z [waterkoeling]€500,- 2x hd5850, Phenom II X4 965 @3.4 GHz Advies Waterkoeling Setup 68
H [Waterkoeling] 250 euro , Phenom 2 x4 965 Advies Waterkoeling Setup 12
