Weer een mooi waslijstje knutsel materiaal besteld ?
MTN94 400ml Spray Paint - 94 / RV 7040 / Pearl Grey
MTN94 400ml Spray Paint - 94 / RV 120 / Wolf Grey
MTN94 400ml Spray Paint - 94 / RV 7016 / Anthracite Grey
MTN94 400ml Spray Paint - 94 / Silver Jewell
10MM (3/8) Koolance High Flow Fitting - G1/4 (1 stuk + slangklem)
Alphacool Aurora HardTube LED ring 16mm deep black (Red)
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 for plexi- brass tubes (rigid or hard tubes) - knurled - chrome
Alphacool Eiszapfen 16mm HardTube compression fitting G1/4 for plexi- brass tubes (rigid or hard tubes) - knurled - deep black sixpack
Alphacool Eiszapfen L-connector G1/4 inner thread to G1/4 inner thread - deep black -
Alphacool HF Y connector 45 1x G1/4OD 2x G1/4ID revolvable - Chrome
Barrow 16/12mm Rigid PETG Hard Tube, 500mm - Clear -
Bitspower G1/4 Acrylic Stop Fitting II
Bitspower Metal Hard Tubing Internal Reamer / Deburring Tool
Bitspower None Chamfer Crystal Link Tube OD 16MM - Length 500mm - Black - BP-NCCLT16ACBK-L500
Custom Laser Service 1
EK-AF Pass-Through G1/4 (Black)
Feser Tube NON-UV - HighFlow - 3/8 ID - 1/2 OD - CLEAR / PURE
Kabelklem 18MM (zelfklevend)
Lamptron SP103 10x RGB-Hub for Aura, Fusion and Mystic
Loctite 401 Secondelijm Tube - 3gr
MTN Primer / Undercoat - 400ml
XSPC 2x5x5mm RGB LED 4Pin Wire
