Socket 1156 onder de € 100,- !
K0G3L
Whether or not you think the Socket 1366 platform is expensive, Intel's upcoming Socket 1156 setups will certainly seem affordable - the Lynnfield CPUs will start at lower prices, the memory is 'just' dual channel, and the motherboards will go down to some sweet price tags. Speaking of sweet price tags, quite a few European online stores have begun listing a P55 motherboard that upon release would cost under 100 Euro.
Going as low as 91 Euro according to one store, the Gigabyte P55M-UD2 is a microATX motherboard (almost) ready to embrace the Lynnfield processors and take on AMD's AM3 platform. The board's specs are unfortunately not available but we'd expect it to have four DDR3 memory slots, one PCI-Express x16 slot, and the usual - six SATA ports, Gigabit Ethernet and 7.1 channel audio. Hopefully the current prices paired up with the P55M-UD2 will be maintained (or lowered) when the motherboard ships. Wait for it.
source : TechConnect Magazine - Sub-100 Euro P55 motherboard listed
Freddy Intel LGA-1151 (Socket H3) Skylake i5/i7 -> zelfde montage als 1150, 1155 en 1156 Hardware & Software 6
R [IN-ACTIVE] Moederbord socket 1156 Gevonden 6
B socket 1155 -1156 koelblok? HighFlow Webshop 2
XenoMorpH Past Socket 1155 ook op 1156? Waterkoeling 4
Sw333t Waarde socket 1156 setup Gesloten 11
E [IN-ACTIVE] CPU block socket 1156 Gevonden 2
M [INACTIVE] socket 1156 koeler Gevonden 19
dark viper zwolle Adapter, Intel Socket 1156 (CPU-350) HighFlow Product Suggesties en Nieuws 1
P socket 1150 EK-Supremacy MX voor socket 1151 Waterkoeling 2
Ubbidude EK-Extender G1/4 Socket HighFlow Product Suggesties en Nieuws 1
G waterkoeling voor dual xeon (socket 771) fileserver Advies Waterkoeling Setup 8
Source [GEVONDEN] CPU koeler Socket 1150 (lucht) Gevonden 3
V [Waterkoeling] i7-5930K-, Socket 2011-3, Rampage V, EVGA GeForce GTX980, Obsidian900 Advies Waterkoeling Setup 13
E [Waterkoeling] Innovatek, i7 4790K (socket 1150) Advies Waterkoeling Setup 2
Aequitis [GEZOCHT] Iemand met een socket 2011 CPU Hardware & Software 1
D asus maximus formula VI formula 1150 socket in corsair 750D Handleidingen en Installatie Tips 4
D Corsair H100i op AM3+ socket Handleidingen en Installatie Tips 1
stefan787 Intel Core i7 3820 of en andere 2011 socket cpu Gevonden 0
T Socket 1150, backplate zelfde als 1155? Waterkoeling 1
maomanna [GEVONDEN] C13 male socket Gevonden 13
M Socket 775 quad core, DFI lanparty x48, Antec 1200 Advies Waterkoeling Setup 2
P [GEVONDEN] Socket 775 en socket AM3 Processoren en Moederborden, Game PC Neefje. Gevonden 5
marcel87 [VERKOCHT] Intel C2DM P8400 (socket P) Verkocht 2
Sw333t [IN-ACTIVE] Pentium Gxxx / Core i3 / i5 cpu (de niet K-modellen), socket 1155 Gevonden 0
Zwelgje Phobya Screw DIN 912 M4 x 50mm Hexagon Socket (4 Pack) - Black Nickel HighFlow Product Suggesties en Nieuws 3
K Winkelwagen Controlen, Socket 2011 Advies Waterkoeling Setup 6
B [Watercooling] €1000 socket 1155 , 2xgtx580 antec darkfleet df-85 Advies Waterkoeling Setup 12
W Apogee XT & Socket 2011 Waterkoeling 3
R Rampage IV extreme Socket 2011 met een i7-3930k 3.20 ghz processor overclocken? Overclocking 4
R Overclocken i5 2300 Sandy Bridge 1155 Socket Overclocking 5
M socket 370 wc block Waterkoeling 9
olympus [GEVONDEN] Intel i5 (i7), socket maakt niet uit Gevonden 15
Y Watercool HeatKiller HK3.0 Socket 2011 retention bracket HighFlow Product Suggesties en Nieuws 3
J [IN-ACTIVE] X6800 Socket 775 CPU Gevonden 2
P Scythe Shuriken Rev. B SCSK-1100 4-pin on old (supported) 3-pin Socket 478 mobo Overige Koeling 1
Robin026 [GEZ] Socket 775 Moederbord. Gevonden 1
Sw333t [CANCELLED] Socket 775 moederbord, cpu + 4 gb ram Gevonden 4
Sw333t Socket 478 set Gesloten 6
lauwagie [waterkoeling] Intel Socket 1366 : Core i7-990X en SLI ZT-50303-10M Geforce GTX560 Ti Advies Waterkoeling Setup 108
K Iemand een Leen CPU voor Socket 1155? Hardware & Software 13
Source Socket 775 setje Gesloten 10
Sw333t Waarde van deze setup (socket 775) Gesloten 9
Marcel2102 [IN-ACTIVE] Een compleet wc set voor weinig, socket 775 Gevonden 4
