Review: Comparison between 3/8" + 5/8" Tubing - Tygon-Masterkleer-Primochill-Koolance
bundymania
Hey guys,
today I want to introduce you to some new variants of tubing, some of which haven't been out too long.
This roundup is mainly about the popular sizes (in europe) 13/10mm (3/8") and 16/10mm (5/8"). While you were pretty much stuck with only a few choices for these sizes in the past, there's now a range of different brands and colors available to choose from.
When choosing the size of the tubing, it's important to know which requirements the product should meet and you shouldn't just pick one that's fashionable at the time. Even though the 16/10 (5/8") tubing can outperform the 13/10mm (3/8") when it comes to the bending radius, it's not always the best choice because of its sausage-style looks. Overall, the radii of high quality 13/10mm tubing are usually more than enough for most users, anyway. 13/10 tubing by Primochill and Koolance can, for example, achieve radii a lot smaller than those of Masterkleer tubing.
When taking a look at the larger 16/10mm tubing, the difference in radii are only minor, so the more important aspects are the color and the price. A long time there was no way around Tygon tubing, because of the awesome bending radius and its clear looks, even though you paid 10€/meter for it. Luckily, there are now several other competitors available that can take on the Tygon in both these aspects.
Last but not least, there's also the 19/13mm royalty, which appears to take the same route the 16/10 took: except for a few exemptions the only differences are, once again, in the color and the price.
Also, before buying your favorite tubing, be sure to think about what case it's supposed to be used in. When, for example, using 11/8mm tubing (which offers great bending radii), it'll almost look lost in a Big Tower case, which wouldn't be the case when using 16/10mm. On the other hand, 11/8mm can be the best choice in tiny cases, like those used for HTPC´s, to avoid having to use angled fittings or anti-kink-springs.
Also, there's the choice of colors: a lof of the new tubing is UV reactive, making it easier to create some accents in a watercooling-loop in the dark when using a UV light. Of course, this isn't everybody's style and some of the UV tubing has the disadvantage of a slight blue color, that can be very visible on black, clear or white tubing. Those who don't want this effect should try to look out for tubing that's not UV reactive.
So let's get to the most important part, comparing pictures. I'll start with the 13/10mm (3/8") tubing.
The white versions of Masterkleer and Primochill tubing are first:
(Please excuse the stains on some of the UV pictures, coming from some faulty 19/13mm tubing, that marked off on the rest)
Masterkleer: 3.99 Euro / per meter
Primochill: 5.99 €/m
Here's a three-way-comparison between Koolancetubing 13/10mm (uv reactive), Primochill Primoflex Pro 13/10mm and Tygon 12.7/9.5mm tubing
As you can see, the expensive Tygon scores best when it comes to transparency.
Tygon: 6.99€/m
Primochill: 5.99€/m
Koolance: 4.49€/m
Also, there's Masterkleer tubing in this size for only 2.69€/m, but it also offers very poor bending radii when compared to these three rivals.
Here's a picture comparing Primochill in 13/10mm and 16/10mm with Masterkleer in 13/10mm (3/8")
Still, to be frank, even the cheapest Masterkleer tubing is sufficient for most uses.
Next one is a comparison between green Masterkleer, Primochill and Koolance in 13/10mm.
Masterkleer: 3.99€/m
Primochill: 5.99€/m
Koolance: 4.49€/m
The Koolance and Primochill tubing are about the same when it comes to bending radius, though the one by Koolancetubing is a bit stiffer, resulting in more pressure on the waterblocks.
Let's get to the very popular color blue! Prices are the same as the other colors by those companies in this size.
As you can see, the Primochill tubing isn't UV reactive.
Next is the black 13/10mm tubing. Once again, the variants by Koolance and Primochill aren't UV reactive, avoiding the blue sheen seen on the Masterkleer, which is a result of the UV particles.
Now it's the turn of red Masterkleer, Primochill and Koolance tubing, looking like this in daylight and UV light:
So let's get to 16/10mm (5/8") tubing. As said before, there aren't any big differences concerning the radii.
I especially like the Primochill, offering very tight bending radii and very clear looks at 6.29€/m.
Comparison between Primochill 16/10mm and Clearflex 15.9/9.5mm:
Koolance also offers large tubing, but sadly only in 16/13mm variants, that kink a lot earlier than 16/10mm because of the thinner walls.
This is what Koolance offers in 16/13mm:
Priced at 5.99€/m, you can see a huge difference to the 16/10mm tubing in the pictures of the green variants.
Coming up is a comparison between the popular Masterkleer 16/10, an XSPC 15.9/9.5mm tubing and the almost unknown Nalgene 15.9/11.1mm.
The Nalgene scores best when it comes to bending radius, closely followed by the Masterkleer and XSPC.
Nalgene 5.99€/m
Masterkleer 4.99€/m
XSPC 2.79€/m
One thing I didn't like about the Nalgene tubing is the continuous writing on the walls, so I'd probably choose a competitor.
Black tubing also gets more and more popular so here are the most commonly used variants in 16/10mm (5/8") :
It starts with Masterkleer 16/10mm for 4.99€/m, followed by Tygon 15.9/9.5mm for 9.99€/m and ends with Primochill 16/10mm for 6.29€/m.
Only the Masterkleer tubing in this comparison is UV reactive and the Tygon offers the best bending radius.
Next up is a larger comparison of Masterkleer and Primochill in 16/10mm (5/8") - get your own impression of the colors blue, red, green, white and silver!
I'll close with a bending comparions of rather unknown, but very good tubing: Nalgene 19/13mm (1/2"):
I hope that my little overview could be of some help when choosing the right tubing.
This roundup will probably soon be expanded with other variants, but for now I can't see any more tubing in this amount or I'll get nightmares.
Until the next review,
the Bastelorakel.
Thanks go out to the companies for providing the samples and my girlfriend for her patience until 80 meters of tubing were stored away after days of taking pictures.
Lereno
Nice bundy, u rock ;d
I have some problems viewing pics tho, they don't go "full size" but keep small size :( Do u got link to this review on another board maybe?
edit: nvm, just saw you on OCN ;)
bundymania
- Update 24.01.11 -
Mittlerweile ist der Masterkleer Schlauch in einer verbesserten Version erhältlich ! Zudem sind nun weitere Farben (gelb, orange, pink und purple) verfügbar ! Für die neuen Bilder habe ich den Schlauch in der Größe 13/10mm und 16/10mm erhalten. Beim 13/10er ist mir aufgefallen, das dieser nun ein wenig knickresistenter ist. Allgemein sind die Farben nun schöner, ähneln dem beliebten Primochill sehr und der MK Schlauch ist im Vergleich günstiger ! :bigok: Der zuvor beanstandete "Blauschimmer" , besonders bei den Farben schwarz und weiss ist mir nun nicht mehr aufgefallen. Die neuen Sorten sind in Retailpaketen der Längen 3,3m und 15 Meter erhältlich.
Preislich liegen die 3,3m Pakete bei 8 Euro für die 13/10mm Version und 12 Euro für die größeren 16/10mm Varianten !
Hier nun Bilder der neuen 16/10mm Versionen in den 3,3m Retail Paketen:
Transparenz- und Knickvergleich Primochill 16/10mm <-> Masterkleer 16/10mm:
Wie man sieht, ist der neue MK Schlauch dem deutlich teureren Primochillschlauch quasi ebenbürtig, sowohl vom Knickverhalten, als auch von den Farben !
Ich verleihe den neuen Masterkleer 16/10mm Schlauchsorten daher den Preis/Leistungs Award !
Und hier nun die Bilder von den 13/10mm Masterkleer Schläuchen:
(2-3 Sorten habe ich nicht abgelichtet, da optisch identisch zu den bereits vorgestellten alten MK Versionen !)
Die neuen Masterkleer Schläuche stehen ferner in den folgenden Größen zur Verfügung: 10/8mm , 11/8mm , 15,9/11,1mm , 15,9/12,7mm sowie 19/13mm !
Neue Alphacool HF 13/10mm Schläuche:
Aus dem Hause Alphacool.de habe ich ebenfalls neue Schläuche erhalten. Diese Schlauchsorten werden laut Hersteller in den USA hergestellt und können durch schöne satte Farben überzeugen. UV aktiv ist der neue Alphacoolschlauch nicht, was den Vorteil hat, das hier keine Farbabweichungen vorkommen. Was die Knickstabilität betrifft, muss sich dieser Schlauch hingegen von Primochill und Koolance geschlagen geben und ist derzeit nur in der Größe 13/10mm zum Preis von 4,95 € pro Meter erhältlich.
Anbei der Link zu den Schläuchen:
Alphacool Schlauch HF 13/10
Dieser Schlauch steht derzeit in den Farben rot, blau, orange, schwarz, klar, weiss und grün zur Verfügung !
Vergleich Alphacool HF 13/10mm grün <-> Masterkleer 13/10mm grün :
Dies als Beispiel, damit man sich den Unterschied in der Transparenz besser vorstellen kann.​
bundymania
NOW IN ENGLISH :)
- Update 01/24/11 -
Meanwhile, the Masterkleer tubing is available in a revised and improved version, also featuring the new colors: yellow, orange, pink and purple). I received tubing in 13/10mm and 16/10mm for these new pictures. The 13/10 also struck me as being more resistant to kinks as it was before. The colors look better, too – they look a lot like those of the Primochill tubing, while being less expensive. :bigok: The slight blue shimmer I complained about last time is gone now, too. The new versions are available in retail packages of 3.3 (at 8€ for 13/10 and 12€ for 16/10mm) or 15 meters.
Let’s see a few pictures of the new 16/10 versions in the 3.3m packages:
Comparison in transparency and bending radius Primochill 16/10 <-> Masterkleer 16/10:
As you can see, the new MK tubing is equal to the more expansive tubing by Primochill!
Therefore I award the new Masterkleer 16/10 tubing the award for value for money!
And a few pictures of the 13/10mm Masterkleer tubing:
(I didn’t take pictures of 2-3 sorts as they didn’t differ from the old MK versions!)
The new tubing is also available in the following sizes: 10/8, 11/8, 15.9/11.1, 15.9/12.7 and 19/13mm!
New Alphacool HF 13/10mm tubing:
Alphacool.de also sent me some new tubing. It’s made in the USA and also offers rich deep colors, while not being UV active and therefore you don’t see any anomalies in the color. When it comes to bending radius, it can’t quite compete with the tubing by Primochill or Koolance and is currently only available in 13/10mm at a price of 4.95€ a meter.
Here’s a link to the tubing:
It’s currently available in the colors red, blue, orange, black, clear, white and green.
Comparison Alphacool HF 13/10mm green <-> Masterkleer 13/10mm green:
This is an example so you can see the differences in transparency.
Once again, thanks go out to Alphacool - CPU Khlung und Wasserkhlung sowie PC-Cooling und Silent-PC Artikel von Alphacool for providing this tubing.
bundymania REVIEW: Radiator Comparison - TFC X-Changer 480 Quad Radi <-> Mora 2 Pro HighFlow Product Reviews 0
R HighFlow: Customer Review HighFlow Testimonials / Shopreviews 1
bundymania [Bundymania User Review] Drobo 5N2 NAS (GER) HighFlow Product Reviews 0
bundymania [Bundymania User Review] K-GK 1 mechanische RGB Gaming Tastatur von KM-Gaming ! [GER] HighFlow Product Reviews 0
Freddy Ledger Blue Review / Ervaring HighFlow Product Reviews 2
bundymania [Bundymania User Review] Tesoro Gram Spectrum - mechanische Gaming Tastatur [GER] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Externe 3 TB Festplatte - TOSHIBA Canvio Premium [GER] HighFlow Product Reviews 0
bundymania [Bundymania User Review] InnoWAVE Plus - Over The Ear Headphones (German) HighFlow Product Reviews 0
bundymania [Bundymania User Review] UGOOS UT4 Android Media TV Box (GER) HighFlow Product Reviews 0
bundymania [Bundymania User Review] FNATIC Gear Mauspads [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] WASDkeys K200 Gaming Keyboard HighFlow Product Reviews 0
bundymania [Bundymania User Review] WASDkeys M100 Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] GeIL EpicGear Morpha Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Fnatic Gear Rush G1 Backlit Mechanical Keyboard [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Alphacool Eiszapfen Anschlüsse und Adapter in der Übersicht HighFlow Product Reviews 1
iSP Alpenföhn Wingboost 2 120mm Blood Red Review (English) HighFlow Product Reviews 0
bundymania [Bundymania User Review] QPAD 8K Pro Gaming Laser Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] Mionix Castor Optical Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] INNODevice INNOFlask 2.0 Bluetooth Speaker [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] EpicGear GeKKota Ambidextrous Laser Gaming Mouse [deutsch] HighFlow Product Reviews 0
bundymania [User Review] Corsair Strafe RGB - mechanische Tastatur mit MX-RGB Silent Switches HighFlow Product Reviews 0
bundymania [Bundymania User Review] Arctic P614 BT Bluetooth Headset (deutsch) HighFlow Product Reviews 0
bundymania [Bundymania User Review] Shogun Bros Ensense Gaming Headset [deutsch] HighFlow Product Reviews 0
bundymania [Bundymania User Review] RANTOPAD Mauspad Roundup [deutsch] HighFlow Product Reviews 0
Consigliere [Consigliere User Review] Scythe Fuma HighFlow Product Reviews 2
Consigliere [Consigliere User Review] Silent Base 800 van BeQuiet HighFlow Product Reviews 1
Consigliere [Consigliere User review] HighFlow Product Reviews 0
R Shop review HighFlow Testimonials / Shopreviews 0
ProAce [ProAce User Review] In Win 703 HighFlow Product Reviews 4
M Review from an international costumer HighFlow Testimonials / Shopreviews 0
bundymania [Bundymania Video Review] Pumpenvergleich: Alphacool DC-LT 3600 und 2400 [German] HighFlow Product Reviews 0
bundymania [Bundymania Review]Update 3.3.14 - Der große Tripleradiator Vergleichstest ! 26 Rads HighFlow Product Reviews 2
bundymania [Bundymania User Review] Alphacool D-RAM Cooler X4 (für Corsair Dominator™ RAM) HighFlow Product Reviews 0
bundymania [Bundymania Review] Kühlervergleich Reeven Hans RC-1205 vs. Raijintek Themis (deutsch HighFlow Product Reviews 0
