SeaShark
- Razer Chroma Addressable RGB Controller
- Razer
- 40 euro
- https://www.amazon.nl/dp/B08LGQRLXV...e=380333&creativeASIN=B08LGQRLXV&linkCode=asn
- https://www.megekko.nl/product/0/11...rs.net&utm_source=tweakers.net&utm_medium=cpc
- Razer
- Universal compatibility to work with any ARGB device
- 6 addressable RGB headers to connect and control multiple devices
- Powered by Razer Chroma™ RGB for truly customizable lighting
- Supported by Razer Synapse 3 for streamlined control
- SSD mounting points or 3M double-sided tape to securely attach it within your PC case
- 6 Addressable RGB headers (up to 80 LEDs per port, 240 total)
- Support for WS2812b or equivalent LED types
- USB connection (USB 2.0 Micro-B) for data
- Included Molex to DC power adapter for power
- Supports mounting in SSD brackets.
- Double sided adhesive tape included for mounting
- Razer Synapse enabled
- Razer Chroma SDK enabled
- Dimensions : 100mm (3.94in) x 70cm (2.76in) x 18mm (0.71m)
- 40 euro
